Turbo and A/C on a sedan, am I crazy?
Old Mar 10, 2007 | 07:05 AM
groovetini's Avatar
Default Turbo and A/C on a sedan, am I crazy?
So, in short, am I dreaming? I want to keep A/C and PS on my D16. If so, what manifold/turbo would have the clearance? I'm willing to use the half size radiator if I need to. I want to go ahead with research, but I'm not sure if I'm wasting my time.
Old Mar 10, 2007 | 07:10 AM
Got_soy's Avatar
Default Re: Turbo and A/C on a sedan, am I crazy? (groovetini)
PS is overrated, A/c can be kept if you try
Old Mar 10, 2007 | 07:16 AM
MagnaniEG6's Avatar
Default Re: Turbo and A/C on a sedan, am I crazy? (Got_soy)
Yep some companies make AC friendly manifolds
Old Mar 10, 2007 | 07:21 AM
I Have an STD's Avatar
wrenchin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">PS is overrated, A/c can be kept if you try</TD></TR></TABLE>
good contribution
a log manifold will work just fine as long as its a specified EF/PS/AC manifold, which might be a little hard to come by. plan in sticking with no larger than a small T3 turbo.
i short, there is going to be a bunch of custom fab involved, there really is very little room
Old Mar 10, 2007 | 07:38 AM
Got_soy's Avatar
Default Re: Turbo and A/C on a sedan, am I crazy? (I Have an STD)
It was a condensed version of you post.
Learning to weld would give you the best possibilites, alloing you to make the tight turn to the down pipe. YOu could also make you own log mainfold, after some practice, that would allow you to place the turbo exactly where you need it.
Old Mar 10, 2007 | 08:07 AM
wrenchin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">It was a condensed version of you post.
Learning to weld would give you the best possibilites, alloing you to make the tight turn to the down pipe. YOu could also make you own log mainfold, after some practice, that would allow you to place the turbo exactly where you need it.</TD></TR></TABLE>
thats better. yeah, learning to weld is your best to achieve your goals
Old Mar 10, 2007 | 09:03 AM
danmdevries's Avatar
Greddy kits are AC friendly.
xanonymousx
12
Jul 10, 2007 07:28 PM
egekreject
Feb 20, 2007 11:41 AM
integra3586
Jun 14, 2006 05:22 PM
jeffk182
Apr 24, 2006 04:54 AM
ndogg
Dec 24, 2003 10:23 AM
