what head gasket are you LsVtec-Turbo guys using?????
Old Mar 10, 2007 | 05:56 AM
dansred2000si's Avatar
Default what head gasket are you LsVtec-Turbo guys using?????
I am getting ready to mate my head and my block together soon and I am not sure on which head gasket to use??? I am looking to push about 450hp. My block is a B18A1 w/81.5mm Cp's and I am using a B16 head.
I have been considering a cometic head gasket or an OEM, also would I have to get a Ls gasket??? One other question I had was I have seen people use copper spray, is that nesseccary or recommended??
Thanks for the help,
-Dan
Old Mar 10, 2007 | 06:01 AM
97gsrki's Avatar
Default Re: what head gasket are you LsVtec-Turbo guys using????? (dansred2000si)
i run a cometic hg on my ls/vtec set up. They make a gasket specifically for that combination. I didnt use any copper spray or anything just make sure that you plug the (i think its the oil feed for the head so dont quote me) on the back left corner of the head because the block doesnt have a hole o match up wth it and would leak oil everywhere. also my motor is running ~450whp.
Old Mar 10, 2007 | 08:31 AM
zexxbo's Avatar
Default Re: what head gasket are you LsVtec-Turbo guys using????? (97gsrki)
b20 headgasket. im 84mm tho
Old Mar 10, 2007 | 08:33 AM
darksideperformance's Avatar
USE A COMETIC ! I STAND BY THEM I RUN THEM ON MY SUPRA AT 23 PSI NO PROBLEM
Old Mar 10, 2007 | 08:40 AM
Topdawgg's Avatar
Default Re: what head gasket are you LsVtec-Turbo guys using????? (darksideperformance)
OEM
last year I ran the GE 82mm head gasket for my 81.5mm bore... no problems
Old Mar 10, 2007 | 08:42 AM
bigbadboy's Avatar
go with GE or OEM
Old Mar 10, 2007 | 09:49 AM
JoePSI's Avatar
Default Re: (bigbadboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">go with GE or OEM</TD></TR></TABLE>
My bro ordered a 81.5mm GSR headgasket from GE, they sent him an OEM GSR (81mm) gasket but for a cheaper price because they bulk them. His headgasket sealed fine, I'm unsure if this headgasket will work for LS/VTEC Setup but I would assume so.
Old Mar 10, 2007 | 09:53 AM
yee SERIOUS's Avatar
i would go with oem
Old Mar 10, 2007 | 10:43 AM
yaaj1320's Avatar
Default Re: (kidsafe yee)
im using GoldenEagle....i plan on running 500+whp
Old Mar 10, 2007 | 10:55 AM
DaveF's Avatar
Default Re: (yaaj1320)
800 + whp OEM gasket, no problem
EGB18C
May 30, 2009 08:33 PM
DrGrEeNtHuMb
Mar 16, 2009 03:58 PM
PhatBoy5015
Jun 19, 2006 12:44 PM
onlinehost
Nov 14, 2005 08:14 PM
