Sparks shooting from starter?! + where does the fast idle vaccum go?
Shotting a little spark from the starter when ever i turn it on, just got the swap in...
i guess its coming from somewhere behind the starter? also the skreech in the video, I'm also guessing its the alternator belt?
http://www.yourfilehost.com/me...2.AVI
is there supposed to be a nut here? EDIT: THERE IS SUPPOSED TO BE ONE THERE.
First yellow arrow on the left...where does it need to go?
Modified by Dudikoff at 12:20 AM 3/10/2007
left yellow arrow feeds into water pipe behind block, right yellow arrow goes through the throttle body/and/or cold idle valve
and it should be a long bolt, not a nut and stud, so once you get that tightened in, see if it still sparks, it could just be trying to ground
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronhume »</TD></TR><TR><TD CLASS="quote">left yellow arrow feeds into water pipe behind block, right yellow arrow goes through the throttle body/and/or cold idle valve
and it should be a long bolt, not a nut and stud, so once you get that tightened in, see if it still sparks, it could just be trying to ground</TD></TR></TABLE>
i got the one on the right, just can't figure out where the left goes at all. looked as hard as i could on the back the manifold/block and cant find anything.
its a gsr with blox IM.
The one close to the Tb goes to the FITV. The other one goes to the back of the engine(not the intake manifold). The fitting is half way down in between the PCV and the oil filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer »</TD></TR><TR><TD CLASS="quote">The one close to the Tb goes to the FITV. The other one goes to the back of the engine(not the intake manifold). The fitting is half way down in between the PCV and the oil filter.</TD></TR></TABLE>
Ok now im really confused.
so are those not supposed to be connected? and the line im missing is supposed to go where #2 is?
you are right, they do not go there. the left yellow arrow hooks up to red #2.
the black box is part of the vacuum system, and the pipe you have it connected to right now is the water system. basically if you turned the motor on with water in it, it would fill the engine with water into the oil chambers. = bad news.
sidenote: use Wix oil filters. they are way better than frams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronhume »</TD></TR><TR><TD CLASS="quote">you are right, they do not go there. the left yellow arrow hooks up to red #2.
****...so where is #1 supposed to go to? i saw a picture of someone looping those lines on vacuum system, could i do that? http://www.performanceforum.co...0.JPG
Modified by Dudikoff at 12:22 PM 3/11/2007
</TD></TR></TABLE>****...so where is #1 supposed to go to? i saw a picture of someone looping those lines on vacuum system, could i do that? http://www.performanceforum.co...0.JPG
does it really matter which one i route to the top of the IM? cuz i capped off the that goes behind the block or IM and #1. then just ran a line from the other vaccum off the pvc box to the IM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer »</TD></TR><TR><TD CLASS="quote">What you refer to as #1 is the PCV valve and that is supposed to be routed to the intake manifold(vacuum source).</TD></TR></TABLE>
I have a skunk2 manifold on my GSR and the large port on the manifold, I used for my EVAP. the only port left is the small on from the back by the Brake booster port. I got a reducer and routed my PCV there. As long as it is manifold vacuum, you should by fine. The way to check is that when everything is hooked up properly, there should be a slight vacuum at the oil filler hole when the cap is remove while the engine is running.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer »</TD></TR><TR><TD CLASS="quote">I have a skunk2 manifold on my GSR and the large port on the manifold, I used for my EVAP. the only port left is the small on from the back by the Brake booster port. I got a reducer and routed my PCV there. As long as it is manifold vacuum, you should by fine. The way to check is that when everything is hooked up properly, there should be a slight vacuum at the oil filler hole when the cap is remove while the engine is running.</TD></TR></TABLE>
ok cool, i guess i should be fine then.
i didnt know it would be this much of a hassle of a diff IM lol. still need to get a itr throttle cable and bracket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer »</TD></TR><TR><TD CLASS="quote">At the dealer the bracket is like 6-8 bucks and the cable is 35-40. </TD></TR></TABLE>
haha yeah, got a friend that works at honda so he should be able to get acura parts as well with his employee discount. cars been down for so long just because of this and the motor swap. more and more problems
oh yeah, can i reuse the pulley/spring off gsr?
maybe... keeping in mind that the gsr throttle cable is at a completely different angle than a type r TB... (not really sure what chassis/engine/TB etc you are using) if it were me, I would have bought a complete throttle body
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dudikoff »</TD></TR><TR><TD CLASS="quote">
oh yeah, can i reuse the pulley/spring off gsr?</TD></TR></TABLE>
No, if you are gonna use the GSR pulley, then you will have no choice but to use the OE GSR cable. No need to but a Type R cable and bracket if you use the GSR throttle pulley. I ran into the same problem when I did my Manofold conversion. The dearler said you cannot buy the pulley by itself. Only complete with a throttle body assembly. I was like DAMN. An LS pully will work. I got my pully off an Type R TB. I'm not sure but if you can find an LS TB assembly, that'll work too.
StokelesS_g2
Jun 22, 2016 10:48 AM
on me. Supprised no one caught that in the video...
