b18b to b18c1 swap
Old Mar 9, 2007 | 08:29 PM
Gibson5469's Avatar
Default b18b to b18c1 swap
I searched but only came up with lsvtec info.
what's needed to swap from an LS B18B motor to a GSR B18C1 ? Do you need the harness and ecu from a GSR? Could a GSR ECU and LS harness work together? just simple things like this, thanks.
if you have a DIY or page answering these questions I would appreciate that too.
Old Mar 9, 2007 | 10:25 PM
doood's Avatar
been there done that
Default Re: b18b to b18c1 swap (Gibson5469)
unless there's a big *** hole in your current b18b, just boost it. it'll come out cheaper than a b18c1 swap and you'll have more power.
Old Mar 9, 2007 | 10:40 PM
deadline's Avatar
https://honda-tech.com/zero...14995
here this will help...
Old Mar 10, 2007 | 05:51 AM
Gibson5469's Avatar
Default Re: b18b to b18c1 swap (doood)
I'd rather have the all motor reliability and vtec of the b18c1. i've messed with turbo cars, and it's more than I want to deal with for a daily driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zero...14995
here this will help...</TD></TR></TABLE>
thanks
Old Mar 10, 2007 | 09:49 AM
nokturnal_munkeeboy's Avatar
no it wont work together b18b non vtec b18c1 vtec see wut i mean the harness wont work
Old Mar 10, 2007 | 01:30 PM
brokevw's Avatar
Default Re: b18b to b18c1 swap (nokturnal_munkeeboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">no it wont work together b18b non vtec b18c1 vtec see wut i mean the harness wont work</TD></TR></TABLE>
thanks for the wrong information.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by under_psi &raquo;</TD></TR><TR><TD CLASS="quote">you can use your own axles/mounts/shift linkage....your B18B1 is OBD1, if the B18C1 is also OBD1 then you'll only need to add three wires to your own ecu harness. If the B18C1 is OBD2 then it'll be a LOT more complicated...same with JDM(non OBD).
I have an OBD1 B18C1 in my 95 RS and the swap was a sinch&lt;IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emsmile.gif" BORDER="0"&gt; </TD></TR></TABLE>
integra3586
Aug 24, 2009 12:40 PM
pigpen56pb18
Mar 22, 2008 08:13 PM
escape2me
Dec 23, 2004 05:30 PM
Mr Boston
Sep 7, 2003 08:58 AM
Toby1
Mar 29, 2002 11:46 AM
