Exhaust problem with WS2
I just recently put in my Apex World Sport 2 full cat back system on my 02 4DR 4cyl accord. I am having problems with the middle piping (the long straight pipe) , its not really fitting straight on when on together with the rest of the pipe. The pipe is off to the left because I needed to move it like that or else it won't go on the rubber hanger and its smashing onto the heat shield which isn't good either. Also the other pipe with the 90 degree bent with the hanger is also off, I can't hook it on, I feel like I am forcing the whole muffler canister just to make it fit onto the hanger. Seems like the piping if off a bit. Anyone else have this problem or experience something like this?
Modified by JDM Accord 510 at 9:45 PM 3/9/2007
Modified by JDM Accord 510 at 9:46 PM 3/9/2007
i have an ebay cat back on mine, and i had to bolt it up with only one muffler hanger on. made the stretch for the last 3. i think thats easier, instead of fighting pipe, fight rubber...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Accord 510 »</TD></TR><TR><TD CLASS="quote">I just recently put in my Apex World Sport 2 full cat back system on my 02 4DR 4cyl accord. I am having problems with the middle piping (the long straight pipe) , its not really fitting straight on when on together with the rest of the pipe. The pipe is off to the left because I needed to move it like that or else it won't go on the rubber hanger and its smashing onto the heat shield which isn't good either. Also the other pipe with the 90 degree bent with the hanger is also off, I can't hook it on, I feel like I am forcing the whole muffler canister just to make it fit onto the hanger. Seems like the piping if off a bit. Anyone else have this problem or experience something like this?
Modified by JDM Accord 510 at 9:46 PM 3/9/2007</TD></TR></TABLE>
The fitment is perfect if bolt up the exhaust before hand and then have a friend help you hold it up while you connect up the hangers one at a time and finally bolt it to the cat.
ShaolinRider
Sep 8, 2003 07:16 AM
Thanks for the inputs
