Leaking tranny fluid?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">1. Axle seals
2. Rear main seal
3. Bent-up crush washer on the fill bolt
4. Bleed nipple on the top.</TD></TR></TABLE>
its barley leaking just a little wet around the bottom of the tranny, but ill check all those t/m. thanks
2. Rear main seal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">You cannot leak tranny fluid from the rear main seal.
True . . . . I was just thinking of seals I replaced last time I had a tranny out ...
<-- self
<-- self
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Could of been you over filled it, just find out where the leak is from. Was it leaking prior to you re-filling the tranny fluid?</TD></TR></TABLE>
i dont think it was, just swapped the motor in. i filled it in through the vss. i didnt tighten the drain plug enough so it stopped from there but i think its coming from some where else also.
