Grinding into 5th gear
Old Mar 9, 2007 | 04:14 PM
sixfiveoh's Avatar
Sweet Title
Default Grinding into 5th gear
Every gear shifts beautifully except for the 5th, so I'm hoping it's not the tranny. Sometimes there will be no grinding if when I shift, I hold the clutch in untill the RPMs come all the way down, then proceed to shift. Could synchro mesh fluid be the solution to this?
Car is a 1990 Integra w/ 199k on both motor and tranny.
I remember a while back, my mechanic told me that I would need bearings soon. Could this be the cause?
Old Mar 9, 2007 | 05:02 PM
goheel's Avatar
Default Re: Grinding into 5th gear (sixfiveoh)
I have the same problem. It's the synchro that's going out. You might want to wait until you change the clutch to change the synchro at the same time. A temporary way to mask the problem is to change the transmission fluid with synchromesh.
Old Mar 9, 2007 | 06:50 PM
t-splice.mn's Avatar
how well does this "synchromesh" work? and where do i get some?
Old Mar 9, 2007 | 07:03 PM
GREENMOB$TER's Avatar
Default Re: (t-splice.mn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t-splice.mn &raquo;</TD></TR><TR><TD CLASS="quote">+2
how well does this "synchromesh" work? and where do i get some?</TD></TR></TABLE>
It's just a temporary fix, and you can get it at a GM Dealer
Old Mar 9, 2007 | 07:32 PM
goheel's Avatar
I just bought 3 quarts of Penzoil synchromesh (which is the same as GM, supposedly). I'll let you guys know how it work after I changed my transmission fluid.
Old Mar 9, 2007 | 09:21 PM
sixfiveoh's Avatar
Sweet Title
Default Re: (goheel)
let us know how it goes
Old Mar 10, 2007 | 12:27 AM
vincent001's Avatar
i changed mine to syncromesh and it still grinds =/ but not as bad
IgnitionZ05
Oct 31, 2006 04:18 PM
korndog
Jan 3, 2005 08:28 PM
RiCE On IcE 2
Jul 26, 2004 04:32 PM
totalfxaccord
Mar 21, 2004 12:18 PM
TrueDC2
Oct 3, 2003 12:13 PM
