precision injectors in d16 fuel rail. Help.
Old Mar 9, 2007 | 04:09 PM
1990si's Avatar
Default precision injectors in d16 fuel rail. Help.
ok i am turboing my 1990 si and my precision 440 cc injectors do not go into the fuel rail far enough. i am pretty sure the seals are going in all the way but the fuel rail doesnt sit right for me to tighten the fuel rail down. any suggestions??
Old Mar 10, 2007 | 04:42 AM
1990si's Avatar
Default Re: precision injectors in d16 fuel rail. Help. (1990si)
bump for help
Old Mar 10, 2007 | 06:45 AM
civicjdmb16a's Avatar
try lubing them with some oil. should fit...
Old Mar 10, 2007 | 06:59 AM
Autoworks's Avatar
Default Re: precision injectors in d16 fuel rail. Help. (civicjdmb16a)
You have to bore the grommet or shave the injectors
Old Mar 10, 2007 | 08:58 PM
1990si's Avatar
Default Re: precision injectors in d16 fuel rail. Help. (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">You have to bore the grommet or shave the injectors</TD></TR></TABLE>
which grommet? the o rings do not look like they are holding the injecters back from fitting. it looks like the injecter does not go into the fuel rail/im far enough. i noticed there is some plastic on the injecters i could trim but i do not want any leaks
Old Mar 11, 2007 | 05:08 AM
Autoworks's Avatar
They'll fit into the rail, but not into the intake manifold.
Old Mar 11, 2007 | 09:10 PM
1990si's Avatar
so what do you recommend i do to the im to make them fit?? what do you mean by boring out the grommets??
Old Mar 12, 2007 | 08:28 PM
1990si's Avatar
bump for help. still cannot get them to fit.
airwalk07143
Dec 30, 2008 05:56 AM
aznboi_2
Oct 22, 2008 10:47 PM
hotrod99
May 18, 2007 04:18 AM
b20ek
Jun 29, 2003 06:51 PM
