b16 generations
Old Mar 9, 2007 | 03:35 PM
JDM*addiction's Avatar
Default b16 generations
is this acurate?
it's from wikipedia. http://en.wikipedia.org/wiki/Honda_B_engine#B16A
[edit]B16A
Note: All JDM B16a engines are marked as 'B16a' (with no number to identify version).
VTEC
Found in:
1989-1993 JDM Honda Integra RSi/XSi (DA6/DA8)
1989-1991 JDM Honda CRX SiR (EF8)
1989-1991 JDM Honda Civic SiR/SiRII (EF9)
Displacement: 1595 cm³
Compression: 10.2:1
Rod/stroke ratio: 1.74
Power: 158 hp @ 7600 rpm & 112 ft·lbf @ 7000 rpm
Transmission: S1/J1/Y1/A1
1992-1995 JDM Honda Civic SiR/SiRII (EG6/EG9)
Compression: 10.4:1
Power: 168 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
Transmission: S4C
1992-1995 EDM Honda Civic VTi
Power: 158 hp @ 7600 rpm & 116 ft·lbf @ 7300 rpm
1992-1996 JDM Honda CR-X del Sol SiR
Compression: 10.2:1 / 10.4:1
Power: 158 hp - 170 hp & 111 ft·lbf - 116 ft·lbf
[edit]B16A1
VTEC
Found in:
1989-1991 EUDM Honda CRX 1.6i/VTi (EE8/ED)
1990-1991 EUDM Honda Civic 1.6iVT (EE9)
Compression: 10.2:1
Power: 150 hp (112 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
[edit]B16A2
VTEC
1992-2000 Honda Civic EDM VTi (EG & EK)
Compression: 10.2:1
Power: 158 hp @ 7600 rpm & 113 ft·lbf (153 N·m) @ 7300 rpm
Transmission: Y21
1999-2000 Honda Civic Si (EM1)
Compression: 10.2:1
Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
Transmission: Y21 S4C
1996-1997 Honda Del Sol VTEC (EG)
Compression: 10.4:1
Power: 160 hp (119 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
Transmission: Y21
[edit]B16A3
VTEC
Found in:
1994-1995 Honda Del Sol VTEC (EG)
Compression: 10.4:1
Transmission: Y21
i was just wondering because there is the OBD0, OBD1 AND OBD2 ... so 1st gen 2nd gen and 3rd.
i did search but i was confused about some things. like the B16A1 and where that falls into place what gen it is where it came from. usdm all that
Old Mar 9, 2007 | 03:43 PM
Default Re: b16 generations (hellxno)
so?
1989-1991 JDM Honda Civic SiR/SiRII (EF9) OBD0 1STGEN
1992-1995 JDM Honda Civic SiR/SiRII (EG6/EG9) OBD1 2NDGEN
correct?
----is about what im asking but they both have B16A on the block what codes tell you which is which..... ?
Old Mar 12, 2007 | 06:07 PM
anyone?
Old Mar 14, 2007 | 12:08 PM
Default Re: b16 generations (X EF*Killa X)
pr3 pistons are 1st gen and p30 are 2nd i've learned that so far..
but i keep reading places that say B16A2 is the 92-95 SIR-II engine... is this a misconception or did they do a JDM 92-95 B16A and B16A2??
Old Jun 4, 2012 | 06:43 AM
Hoffer 10's Avatar
im sorry if i seem stupid but are the 2nd gen b16a and b16a2 heads the same, i wanna just be sure cuz i wanna buy an intake manifold, throttle body and cams for it but i wanna make sure the parts will fit the 2nd gen jdm head since they are for a b16a2
Old Nov 22, 2023 | 04:10 PM
B16A_EF_JC's Avatar
8 also years late to the party? Anyway! P30 ECU w/ JDM B16A out of a del Sol in my EC9 Hatch, stock tune but with a Hondata s300 V3 chip (pending tuning) VTEC engages @ 4800rpm and I’ve had her up to 151MPH!
TaffetaEj6
18
Jan 5, 2016 02:54 PM
habanerored06si
Mar 23, 2012 10:52 AM
Fezzie
Sep 11, 2006 10:25 AM
Focus Boy
Acura TL, RL & ZDX
Jul 21, 2003 01:31 PM
sslude
Feb 28, 2003 09:13 PM
