Camber kits?
Old May 22, 2002 | 04:21 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Camber kits?
I was just looking at Eibach's camber kit on overboost. For a car that is tracked would this be a useful mod? Sure would be nice to have the extra adjustability, but was wondering if it might be a waste of $200. Any info would be appreciated.
Old May 22, 2002 | 04:28 PM
Hybrid ctr's Avatar
Default Re: Camber kits? (ActiveAero Ninja Edition)
*fixed*
Old May 22, 2002 | 04:57 PM
BABY NSX's Avatar
As your driving level improves you will want to be able to dial in the camber to achieve the best set-up for the given conditions.
If you are just getting started it might not be the best place to start.
Most camber kits are designed to add positive camber to lowered vehicles. This is not what you want to do generally on a track car. Often you will find that -2 to -3 degrees negative camber is what will get you around the track quickest. To achieve these camber settings you will likely need to add negative camber even to a lowered vehicle.
In other words, if your are going to be getting a camber kit for your car for track purposes make sure you get a kit that can add and remove camber. This is particularly important for front camber kits as most only allow you to add positive camber. Rear kits generally allow both positive and negative adjustments.
Hope that helps.
Old May 22, 2002 | 05:32 PM
Cosworth's Avatar
Nah... tires are a wear-item anyway.
Just go neg camber for a while.
Old May 23, 2002 | 12:14 AM
EagleR's Avatar
Default Re: Camber kits? (Cosworth)
who makes a kit for DC2r's that allow more neg camber to be put into the setup? I would like too have that peice. Links and Price if ya have em please.
mattdenali
Suspension & Brakes
May 26, 2005 09:21 PM
pcorad
Dec 1, 2002 06:18 PM
AxznBlitz
Aug 13, 2002 09:15 PM
Anderson
Jun 18, 2002 01:06 PM
