Honda S2000 Honda S2000
ground control spring is good idea for lowering the S ?
Old Mar 9, 2007 | 01:37 PM
s2kwildride's Avatar
Default ground control spring is good idea for lowering the S ?
I'm looking for lowering my s2000 05 , all the springs seems to not to drop the car enough or , just to much ... I heard about ground control, they come with eibach springs.... somebody have them ? someboday have heard anything about them ?
Thank you
Old Mar 9, 2007 | 02:21 PM
LAS2K's Avatar
Default Re: ground control spring is good idea for lowering the S ? (s2kwildride)
good semi coilover combo for a mod'er on a budget.
Old Mar 9, 2007 | 03:04 PM
Tyson's Avatar
Default Re: ground control spring is good idea for lowering the S ? (LAS2K)
with GC, you only got two choices of shocks tho. oem or koni.
im going to be testing out some GC springs on oem shocks soon (a spare set, not my originals). i had to lathe the sleeves from my civic kit down just a hair for it to fit. but theyre absolutely snug now. got some moderate spring rates shipped to me yesterday. i just need to clean up the shocks and install.
Old Mar 9, 2007 | 04:58 PM
HighPsiAwd's Avatar
Default Re: ground control spring is good idea for lowering the S ? (Tyson)
I have them and love them. Can't beat them for the price
Old Mar 9, 2007 | 05:10 PM
LAS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">with GC, you only got two choices of shocks tho. oem or koni.
im going to be testing out some GC springs on oem shocks soon (a spare set, not my originals). i had to lathe the sleeves from my civic kit down just a hair for it to fit. but theyre absolutely snug now. got some moderate spring rates shipped to me yesterday. i just need to clean up the shocks and install.</TD></TR></TABLE>
why would you on oem shocks out of curiousity? you wont have the dampening ability and your oem's will go out in probably a year to two.
Old Mar 9, 2007 | 05:20 PM
Tyson's Avatar
because they were free.
the lathe work was free.
the springs were gotten at a good deal and can be reused or resold.
i can reassemble a new set of full shocks with parts in my garage. (same as civic parts)
i cant say i believe what ppl say about OEM shocks not lasting. im going to test it out myself on some already used and "tired" set of shocks.
Old Mar 9, 2007 | 05:38 PM
You have them on oem original shock ? What about the durability of your shock with ground control ?
Thanks
Old Mar 10, 2007 | 02:27 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">because they were free.
i cant say i believe what ppl say about OEM shocks not lasting. im going to test it out myself on some already used and "tired" set of shocks.</TD></TR></TABLE>
not so much of they don't last but the damper rate is not make for the GC
it doesn't really matter how little you pay but messing up the suspension and alignment for some freebie isn't just worth it imho.
but againn, it's your car so here a hug and good luck
Old Mar 10, 2007 | 06:44 AM
Default Re: ground control spring is good idea for lowering the S ? (iam7head)
But ground control is gonna be bad for the shock oem as a set of coil springs like espilir ou tanabe ? the only difference is i can adjuste the height , not ? So now idont want spend to much money on the car ...... this is the reason why im interest in ground control ... i kown that shock rate is not ok ... but the ride is gonna probably be like espilirs ? The ride is gonna be really worse than the original setting ????
Thanks
Old Mar 10, 2007 | 07:18 AM
Will_ChinLee's Avatar
The ride quality will be much worse with the ANY lowering spring / OEM shock combo. the stock suspension is one of the best out there. I know a few guys who time attack their S2ks and they ran faster times with OEM set up. However this was most likey due to the fact that their Coilovers weren't set up correctly for the track. In either case, unless your investing over 2k in a full coilover setup your just ruining your cars handling.
But like iam7head stated. "it's your car"
I personally am running Tein RAs, couldn't be happier with that setup. Recently a buddy of my was over at Dynamic Autosports and the C-west time attack S2k was there and we were both supirsed they were running Teins as well. Most likely the SRC or RSs.
Modified by Will_ChinLee at 1:31 AM 3/12/2007
Old Mar 10, 2007 | 01:57 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (Will_ChinLee)
It runs the SRCs.
Old Mar 16, 2007 | 12:43 PM
Tyson's Avatar
i havent even told you guys what spring rates im using...
im gonna be testing camber and toe curves vs height as well with this for my own knowledge. but you know, im just trying to mess up my suspension cuz i dont know wtf im doing. damn i knew i should have gone jdm.
Old Mar 16, 2007 | 05:31 PM
jeremyvr6's Avatar
ive run gc's w/yelows on both of my s's and i couldnt be happier. plenty of options for spring rates plus you get the stand up warrenty of koni. my first set-up is on it's third car and probably has 30k on them and behave just like when i bought them.
Old Mar 17, 2007 | 12:53 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">i havent even told you guys what spring rates im using...
iam7head likes to assume. He's an "expert" on s2ki.
CivicSi95
Suspension & Brakes
Jun 29, 2009 11:12 PM
threesixes
Suspension & Brakes
Feb 5, 2007 10:13 AM
koulaid
Suspension & Brakes
Nov 18, 2006 06:10 AM
champLSinteg
Suspension & Brakes
Mar 1, 2006 12:11 PM
SpecialEdScott
Mar 1, 2003 01:12 PM
