DX tps for an Si?
Si tps is broken. DX is good. will DX work? i know it's backwards or something? it's been a looooong time since i've played with EF's. thanks
i tried searching.. nothing specific, and there are over 380 MPFI swap threads.. and i don't have the time to look through each one.
i asked this question a while ago and all i got was straight up no, it wont work. so im assuming it wont work and passing on the knowledge.
well, i just figured it wouldn't right now too. i pulled them both off.. dang it. time to go to the junkyard.
in any case the actual reason is the fact that the "nub" that engages the TPS is in a different spot on the DX one.
thank you garageEF for your help.
They are opposite of each other and they won't work. I have one sitting on my shelf if you can't find one at the junkyard. I have a DX and an Si one. The Si type is the most common type and you'll find them anywhere. I've used it on my B18c for troubleshooting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF »</TD></TR><TR><TD CLASS="quote">. if im not mistaken the tps on si throttle bodys is non removable/adjustable. </TD></TR></TABLE>
You are mistaken. You have to dremmel a slot into the the metal tab and unscrew it. It's just a screw with no type of notch for a screw driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex »</TD></TR><TR><TD CLASS="quote">
thanks for the info
</TD></TR></TABLE>thanks for the info
i've gotta hit up the junkyard on monday.. we'll see what happens.. thanks though! found another sensor that was damaged on the motor.. also have a few plugs left over from the mpfi swap. i think i messed up. only one way to find out!! woot!
You mention you have an extra TPS for a DX. Would you be interested in selling it?
here is my problem:
https://honda-tech.com/zero...18967
here is my problem:
suspendedHatch
Sep 1, 2006 07:43 AM
Nerologic
12
May 21, 2003 11:08 PM
simike
Aug 13, 2002 02:50 PM
