Is a $500 turbo setup possible?
Old Mar 9, 2007 | 11:19 AM
RS'R''s Avatar
Default Is a $500 turbo setup possible?
I've got $500 in the bank and a friend selling his IC and new t3 .42 trim for $200. Its a steal, and I want to boost my car. I'd be aiming for 200whp running around 6 psi. This is on a stock b18b with 162k miles on the clock with stock replacement clutch and exhaust. In all seriousness could I piece something together for $500-600?
Old Mar 9, 2007 | 11:27 AM
GoldCoin's Avatar
Default Re: Is a $500 turbo setup possible? (RS'R')
possibly. maybe around 500-800 is a better estimate. but be patient and its possible.
Old Mar 9, 2007 | 11:45 AM
RS'R''s Avatar
What is a basic shopping list of must haves? The lists vary a bunch out there.
Turbo (duh)
Turbo manifold
Downpipe
FMU
Manual boost controller
IC + piping
Do I need a new exhaust? My clutch has 2000 miles on it and its a stock replacement. Could it handle 160+/- tq
Old Mar 9, 2007 | 11:47 AM
EJ1 wilcox's Avatar
Default Re: (RS'R')
It's possible, but it will be ghetto as hell.
If you want to do it right, you need to spend some more cash. I just finished up a budget turbo build and I spent right around $1300.
Old Mar 9, 2007 | 12:30 PM
RS'R''s Avatar
Default Re: (EJ1 wilcox)
even if my friend makes the mani and piping etc...?
Old Mar 9, 2007 | 12:37 PM
soundFX's Avatar
Default Re: (RS'R')
sounds like a shitty setup to me and will prolly cause problems but ur call. i on the other hand would definitely not go with that cheap of a setup. boost puts enough pressure on ur motor. something of no quality will not help that
Old Mar 9, 2007 | 12:46 PM
sauceja's Avatar
Default Re: (RS'R')
You gotta think about couplers, clamps, oil lines, don't use an FMU if you like the car so crome or something. Misc random **** that always happens.
You are on the right track though. I would say with time and patience 1000.00 is a very good budget to try and stick with.
But that is without injectors or a tuning system.
Old Mar 9, 2007 | 12:51 PM
EJ1 wilcox's Avatar
Default Re: (sauceja)
It will cost more if your friend makes the mani/piping etc.
Materials alone on a manifold are over $100, piping and flanges will be at least another $150-$200 if you are lucky. Then couplers, a blow off valve, etc. it adds up really really quickly.
.brian.'s Avatar
do you understand it will cost you about $500 for a good tune?
don't spend all of the money you have in the bank on your integra.
edit: here is a link from one of the best tuners in the NE and the prices
http://www.evans-tuning.com/pricing.html
Old Mar 9, 2007 | 01:33 PM
BlakeJ53's Avatar
http://www.Homemadeturbo.com
Old Mar 9, 2007 | 02:15 PM
LordAphotic's Avatar
it cant realistically be done because the turbo would cost around 200$ mininum and a decent wastegate is atleast 100$ and thats if your super lucky..... intercooler... ill say 20 $ just to throw some slack... injectors..... even dsm injectors run over 70-200$ depending on what you get.
500 isnt realistic..... 800-1000 is defitnatly doable.
Old Mar 9, 2007 | 02:54 PM
bendw99's Avatar
Because you have a car that has fairly high mileage, $500 for a cheap and reliable set-up is a bit of a streach, even with the IC and turbo comming in at $200.
If I were you I would pick up that deal and sit on it for a while. You can piece together a kit for fairly cheap. Save and piece it together, thats how a lot of people on a budget roll. Also realize that tunning will cost you a minimum of about $400~$500.
~Ben
dont_tri
Jul 1, 2008 04:40 AM
ctownintegra
Nov 16, 2006 04:34 PM
19sec beast
Mar 20, 2005 06:50 AM
sepulchralx
Sep 10, 2004 11:24 AM
