Rear Brakes
Old Mar 9, 2007 | 10:49 AM
spooncivic01's Avatar
Default Rear Brakes
I am looking at a wrecked 93 Del Sol Si that is local to me that has all the Rear suspenion still intact. I wanted to know if those rear brakes will bolt up to the 88 CRX and I also wanted to know if the Master Cylinder, Brake Booster and Proptioning Valve would be good to get as well. I searched but could not find an exzact answer. Thanks for all the help.
Old Mar 9, 2007 | 01:36 PM
dr_latino999's Avatar
Default Re: Rear Brakes (spooncivic01)
RTA = Good
Brake MC + Booster = Why, aren't they ABS?
Proportioning valve = Again, isn't it for ABS?
Old Mar 9, 2007 | 01:42 PM
garageEF's Avatar
Default Re: Rear Brakes (dr_latino999)
get the trailing arms, then find a ef si mc and prop valve
Old Mar 9, 2007 | 02:51 PM
CRX Toad's Avatar
Default Re: Rear Brakes (garageEF)
If the Del Sol has a booster with a 230v or 260v tag on it then pick it and the master cylinder also. It is a great upgrade.
woahdelsol
Suspension & Brakes
Oct 8, 2012 05:04 AM
Fo-Do Fanatic
Aug 9, 2010 02:35 AM
1LowSol
Jan 11, 2009 11:56 AM
B16Jacques
May 6, 2005 12:43 PM
DMF
19
Jul 22, 2003 09:15 PM
