B16A2 Head Intake and Exhaust Questions
Old Mar 9, 2007 | 10:46 AM
g2tegsown's Avatar
Default B16A2 Head Intake and Exhaust Questions
Ok I have a B16A2, when I bought the engine it had a Skunk2 IM (Old Style), AEM CAI (I believe 2.75" Diameter), and I believe the stock Throttle Body. What I am trying to do is port match everything, but I got to thinking, is there any sense in doing any intake work with a non ported head? I mean can the stock Head flow more air than the stock components provide? For instance if I upgrade my Intake, Intake Manifold, and Throttle Body is that going to just cause more resistance?
Old Mar 9, 2007 | 01:35 PM
dr_latino999's Avatar
Default Re: B16A2 Head Intake and Exhaust Questions (g2tegsown)
It wouldn't cause increased resistance because your head is what determines how much air is being drawn in at any time N/A, so you'd never have a case of "too much air" backlog. Now there are issues with flow harmonics in intakes, but that's a different subect; If this was a F/I case it would be different.
Old Mar 9, 2007 | 05:08 PM
g2tegsown's Avatar
Default Re: B16A2 Head Intake and Exhaust Questions (dr_latino999)
Maybe resistance was a bad term to use, what I was talking about was the flow. I know I have read stuff about AEM claiming that there intakes have the optimal flow "pulses", so the air arrives at the right location at the right time. What I am wondering is there a size that works best for stock heads? I have been told the Skunk2 IM (Old Style) has a 60mm inlet vs the stock b16a inlet size of 54mm, and that putting a skunk2 IM on a car without porting, and tuning will cause the car to actually run slower. I don't know if there is any truth to that, the thing that made me start wondering this was becuase I wanted to port match my intake to my intake manifold, however 60mm is only 2.36 inches, well most intakes are 2.5"-3". Is there a pattern? like should the intake be big and scale down to a smaller IM? From what I have been told/read is that port matching with a velocity stack is the way to go for All Motor (short of putting on ITB's).
Any thoughts?
g2tegsown
Aug 21, 2006 01:15 PM
johncarlos
Feb 29, 2004 08:58 PM
Sloth
Mar 22, 2002 10:27 AM
Lookincrazy
Mar 10, 2002 08:31 AM
