Which camber kit
Old May 22, 2002 | 03:40 PM
91kriks's Avatar
Default Which camber kit
I have a crx hf Im gonna lower about 2" maybe more but i need a camber kit (i have ground control c-o's & im saving up for shocks)...what do you guys suggest? How much should i put down on a good one? Also (this is way outta left field) i want a tranny with a closer gear ratio....which should i use
Old May 22, 2002 | 03:47 PM
SC0TT's Avatar
Default Re: Which camber kit (91kriks)
Ingalls makes a good camber kit. Its about $60 bucks per corner. If your using the HF tranny, then go with the Si transmission.
Old May 22, 2002 | 04:03 PM
technine's Avatar
I just saw today they have one on JCwhitney.com for around$70ish for the sprint I think it was camber kit to adjust +- 3degrees. That is what you will need with how low you are gonna go.
wwong510
Feb 13, 2007 11:11 PM
crxhftosi
Apr 26, 2005 07:37 AM
clutch33
Oct 29, 2003 04:54 PM
Blu5GLude
Nov 11, 2002 05:37 PM
DJ:A
Dec 20, 2001 03:02 AM
