Y8 won't start...spark plugs doused with fuel
my D16Y8 will not start. it turns over but is not firing. i believe it is my ignition causig this; more specifically my spark plugs. my car was running rich before ruining spark plugs and it was throwing a code for the map sensor so i replaced it. after doing that, i replaced the spark plugs while i replaced the map sensor. after trying to start the car, the spark plugs are black and wet with fuel. what is causing this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cx-k »</TD></TR><TR><TD CLASS="quote">probably bad map sensor again.</TD></TR></TABLE>
he replaced it already.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoCivic97 »</TD></TR><TR><TD CLASS="quote">my D16Y8 will not start. it turns over but is not firing. i believe it is my ignition causig this; more specifically my spark plugs. my car was running rich before ruining spark plugs and it was throwing a code for the map sensor so i replaced it. after doing that, i replaced the spark plugs while i replaced the map sensor. after trying to start the car, the spark plugs are black and wet with fuel. what is causing this problem?</TD></TR></TABLE>
i don't know why, but did you look into the FPR? what about your o2 sensor?
replace your spark plugs and it should start. I had same exact problem on my ls vtec turbo, it wouldnt start because i was running very rich. Replaced the plugs retuned and it ran like champ. I had cracked downpipe which was causing me to run very rich
i do have a cracked exhaust manifold...header is on the way. map sensor is brand new. ill try to replace the spark plugs in the morning since thats the only thing i can think of right now or actually check the spark first. i need this to run since its my dd...hopefully it works. wish me luck.
jdm_xsi206
Jun 22, 2010 07:55 PM
labtec2
May 25, 2008 05:18 PM
