Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
My 06 Si is BOUNCING off the road when I dump from it 5000 from a stop
Old Mar 9, 2007 | 04:39 AM
mikseries's Avatar
Default My 06 Si is BOUNCING off the road when I dump from it 5000 from a stop
So, when I do a launch, and I dump it from 4000-5000 rpm, my front tires hop up and down off the ground and it feels and sounds like the freakin' motor mounts are going to snap. I still haven't muscled my way through to see what it does. I always pus-out because of the sound. I know it's probably because of LSD and the 17's I have on it. But is there anyway I can resolve this without getting smaller tires?
Old Mar 9, 2007 | 04:42 AM
Type X's Avatar
Default Re: My 06 Si is BOUNCING off the road when I dump from it 5000 from a stop (mikseries)
launch lower & go to the track.
Old Mar 9, 2007 | 04:50 AM
The Answer's Avatar
I would imagine the tires being cold..... not having good road contact would have a factor in the wheel hop. Should be fine summer time, but as Mike said, take it to the track.
Tires=rubber
Cold rubber= contraction (won't stick well)
warm rubber= expansion (sticks well)
Old Mar 9, 2007 | 04:56 AM
blue rocket's Avatar
Default Re: (elklodgeezra)
it also has to deal with the way you let off the clutch...you might have to slip it a bit rather than a complete dump...if you do it right you'll just spin them smoothly. Keep practicing!
Old Mar 9, 2007 | 04:59 AM
The Answer's Avatar
/\ Good point.
Old Mar 9, 2007 | 05:29 AM
CrisEK's Avatar
you have found the infamous wheel hop! a lot of FWD cars have the same problem. Well good luck and happy launching!
Old Mar 9, 2007 | 05:50 AM
soulrider4ever's Avatar
Feathering the clutch pwns j00
Old Mar 9, 2007 | 06:15 AM
IT GUY's Avatar
Default Re: My 06 Si is BOUNCING off the road when I dump from it 5000 from a stop (soulrider4ever)
who else suggests driving school?
Old Mar 9, 2007 | 06:30 AM
originalg00kster's Avatar
Default Re: My 06 Si is BOUNCING off the road when I dump from it 5000 from a stop (IT GUY)
learn on your own. and dont dump....slip the clutch.
Old Mar 9, 2007 | 06:31 AM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikseries &raquo;</TD></TR><TR><TD CLASS="quote"> But is there anyway I can resolve this </TD></TR></TABLE>
Learning the proper way to drive/launch/race the car would be a start..
Old Mar 9, 2007 | 08:27 AM
honda06si's Avatar
Default Re: My 06 Si is BOUNCING off the road when I dump from it 5000 from a stop (TRE_)
you could but the ingnalls torque dampener when it comes out. it helps with wheel hop
Old Mar 9, 2007 | 08:28 AM
honda06si's Avatar
Default Re: My 06 Si is BOUNCING off the road when I dump from it 5000 from a stop (honda06si)
http://www.ingallseng.com/parts/ETD/stiffy.htm
Old Mar 9, 2007 | 08:38 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda06si &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ingallseng.com/parts/ETD/stiffy.htm</TD></TR></TABLE>
Nice.. i guess the delay was no ctr version ebing in japan... the ep3 when it was released this was a mod that was on the shelf from day 1.
Old Mar 9, 2007 | 12:35 PM
Punting_Midgets's Avatar
My car was the test vehicle for the "stiffy"! Dan at Ingalls mentioned it would be out by April or May. I cant wait to get mine!!! Free parts FTW!
Old Mar 9, 2007 | 01:14 PM
John Z's Avatar
sell it and get a geo metro, i dont think uw ill have that problem
Old Mar 9, 2007 | 02:58 PM
20ls01's Avatar
engine torque damper.......get one of thsoe
Old Mar 9, 2007 | 05:59 PM
TRE_'s Avatar
Default Re: (20ls01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">engine torque damper.......get one of thsoe</TD></TR></TABLE>
haha! yea this will totally help out!!!!
Old Mar 9, 2007 | 06:13 PM
20ls01's Avatar
Default Re: (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">
haha! yea this will totally help out!!!! </TD></TR></TABLE>
cant tell if your being sarcastic or not..
Old Mar 9, 2007 | 07:35 PM
Aco512's Avatar
not sure if its available for your cars yet but upgrading the mounts will cure the wheel hop
so you can install
-a touque damper kit
-energy suspension motor mounts
-replace motor mounts
if available on the market
brian15
Apr 19, 2010 07:19 AM
deerman2701
Apr 17, 2008 06:31 PM
DarkSI06
Jun 27, 2006 10:15 PM
91integraLSVTEC
Feb 18, 2006 07:31 AM
DC5_R
14
Oct 26, 2004 08:59 PM
