Honda S2000 Honda S2000
wheel/tire gurus
Old Mar 9, 2007 | 03:39 AM
wifesaynogo's Avatar
Default wheel/tire gurus
i have the factory ap1 wheels on my S and i was looking to upgrade to a set of 17's...the issue is that the S has a large hub bore size in the front preventing me from getting certain wheels...but what i would like to know is: will a 17x7.5 either 45 or 48mm offset and 73mm hub bore all the way around be fine for an only street driven S...if so what size tires would you recommend being that front and rear rims are the same size? if it matters the S is not lowered and if it ever will be it will only be an inch or less...thanx...and yes i did search for an hour last night
Old Mar 9, 2007 | 04:46 AM
fish22's Avatar
Default Re: wheel/tire gurus (wifesaynogo)
someone can correct me if i'm wrong, but i think the fronts are a 73mm bore, and the rears are a 68mm, it might be the other way around though. if thats the case, that would work, all you would have to do is get some hubcentric rings for the wheel thats bore is bigger than the hub. i would prefer non-staggered wheels, your going to disrupt the handleing characteristics a lot.
Old Mar 9, 2007 | 06:15 AM
Default Re: wheel/tire gurus (fish22)
well i would like to get an 17X8+ in the rear but the bore size in the wheel for that size is to small...i may just look for other rims...but if i can counteract the rim width issue by selecting corresponding tires that meet or exceed the tread width and are near the diameter of the stockies both fron and rear i would like to do that
Old Mar 9, 2007 | 07:27 AM
cmdr430's Avatar
you could do that....
if you do, i would go
17x7.5 front 45 offset or 48
17x7.5 rear 48 offset...... with the rear, i would get hubcentric rings
and tires i would run 215 45 front
and 245 40 rear.....
however, i personally would choose other rims better suited for the car....
Old Mar 9, 2007 | 07:33 AM
Default Re: wheel/tire gurus (cmdr430)
yea im considering other rims if i can find something i actually like on formula red...for the hubcentric rings could i get those machined somewhere or would i need to get them from the site i order from... b/c i doubt the site would have em
Old Mar 9, 2007 | 07:45 AM
cmdr430's Avatar
the site that you order the wheels from should sell hubcentric rings
Old Mar 9, 2007 | 08:15 AM
most site sell the rings in sets of 4's and after reading alot of internet jabber i was under the impression that i would need four and not just 2 for the rear...and the front and rear bore size being different i did not want to have to buy 2 sets of 4 rings...im just gonna call around...thanx for your help
well I found my rims in 17x7 45et 73mm bore for the front and 17x8.5 48et 73mm bore for the rears...so all i need now are the rings and a balance between the right tire size, grip and treadwear w/ more of a priority on grip
Old Mar 9, 2007 | 07:06 PM
toofast4u752's Avatar
on stock ap2s i run 215s front and 255 rears. ap2s are the same size as the wheels you just said. i got bridgestone Potenza RE750s they handle great. i believe you can run 225s in the fronts also..
Old Mar 10, 2007 | 05:00 AM
cheese steak Nazi's Avatar
speaking of tire sizes...
whats the widest tire i can run on the rear, without the tires sticking out from the car and looking stupid
Old Mar 10, 2007 | 01:59 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (Cheese Steak ****)
225 or 235/45s fronts, 255, 265/40 rears.
Old Mar 10, 2007 | 03:40 PM
^^ thanks
ej0513
Jan 18, 2009 07:10 AM
itr1235
Nov 27, 2008 08:42 PM
L8apex
May 6, 2008 02:35 PM
celestrium
Oct 5, 2002 08:16 AM
