rpm high
Old Mar 9, 2007 | 01:49 AM
GTEC913's Avatar
Default rpm high
i over rev my car the other and everytime i sart my car on cold start my rpm would be at 2.5 to 2.8 rpm and thats hella high and when its warm its saty to 1.4 rpm ...does anybody know how to deal wit this?
Old Mar 9, 2007 | 01:50 AM
GTEC913's Avatar
Default Re: rpm high (GTEC913)
by the way this is my friends car and its a 92 integra obd1 Ls
Old Mar 9, 2007 | 08:30 AM
t-splice.mn's Avatar
how is the heat? if its not blowing very hot it could be a thermostat
Old Mar 9, 2007 | 02:13 PM
gtec28's Avatar
the thermostat is coo temperature is regular and fan works fine i jus cant figure it out...i was told to check my hoses and my throttle body but my hose dont got no leak can anybody?
Old Mar 9, 2007 | 02:58 PM
Sam92Teg's Avatar
Default Re: rpm high (gtec28)
By over-revving, do you mean you miss-shifted and shot the rpms to infinity and beyond? You might have bent a valve or skipped a tooth on the timing belt. Do a valve adjustment and look at the cam alignment while your there.
Old Mar 9, 2007 | 03:11 PM
davidluko's Avatar
Default Re: rpm high (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">By over-revving, do you mean you miss-shifted and shot the rpms to infinity and beyond? You might have bent a valve or skipped a tooth on the timing belt. Do a valve adjustment and look at the cam alignment while your there.</TD></TR></TABLE>
And what the heck does a thermostat have to do with high idle? haha
Old Mar 9, 2007 | 06:44 PM
Default Re: rpm high (Hatch_R)
when i first bought my 2000 teg, it always idled at about 1600 or so because the thermostat was worn... so the computer thought it was still cold even when it wasnt, keeping the idle high. i replaced the t.stat and problem went away
Old Mar 9, 2007 | 11:48 PM
white-ack-integra's Avatar
Default Re: rpm high (t-splice.mn)
i had the same problem with my 97 gsr. check all the vacume hoses and then adj. the ideler on the throttle body (it's a flathead screw on the throttle body)
Old Mar 10, 2007 | 12:36 AM
xtegb16x's Avatar
Default Re: rpm high (white-ack-integra)
loosen up your dizzy bolts and move ur dizzy..i think clockwise till ur rpm drop a lil and tighten it !
Old Mar 10, 2007 | 10:25 AM
davidluko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t-splice.mn &raquo;</TD></TR><TR><TD CLASS="quote">when i first bought my 2000 teg, it always idled at about 1600 or so because the thermostat was worn... so the computer thought it was still cold even when it wasnt, keeping the idle high. i replaced the t.stat and problem went away</TD></TR></TABLE>
A thermostat stops or starts the flow of coolant to the radiator, mechanically. It doesn't affect the idle at all. Making you're thinking of a temperature sensor.
Old Mar 10, 2007 | 10:48 AM
modthisEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">
And what the heck does a thermostat have to do with high idle? haha</TD></TR></TABLE>
my car when i exit the freeway with bad thermostat the temp. would be all the way on COLD and the rpm would be at 1200-1500 rpm for good 30 seconds then the temp. started going up and the rpm started to drop............i think thats what he means.
Old Mar 10, 2007 | 11:27 AM
200+BHPbabeee's Avatar
Does the word 'choke' mean anything to you?
Old Mar 10, 2007 | 09:05 PM
davidluko's Avatar
Default Re: rpm high (modthisEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by modthisEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
my car when i exit the freeway with bad thermostat the temp. would be all the way on COLD and the rpm would be at 1200-1500 rpm for good 30 seconds then the temp. started going up and the rpm started to drop............i think thats what he means.</TD></TR></TABLE>
Yea I know that it runs at a higher RPM when it's cold but it doesn't run at 2.5-2.8k RPMs... and the OP said that it warms up fine and that it runs at 1.4k RPMs when it's warm. This has nothing to do with a thermostat.
Old Mar 10, 2007 | 09:59 PM
DC2Slow's Avatar
check the TB screw
Old Mar 10, 2007 | 11:55 PM
99Geeezer's Avatar
A thermostat stops or starts the flow of coolant to the radiator, mechanically. It doesn't affect the idle at all. Making you're thinking of a temperature sensor.</TD></TR></TABLE>
The cooling system can effect the idle. Depending on what system, coolant flows through the fast idle thermal valve to aid during cold operation. Not sure if a 92 has a FITV but the newer tegs have them.
Old Mar 11, 2007 | 09:56 AM
davidluko's Avatar
Default Re: rpm high (99Geeezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer &raquo;</TD></TR><TR><TD CLASS="quote">
The cooling system can effect the idle. Depending on what system, coolant flows through the fast idle thermal valve to aid during cold operation. Not sure if a 92 has a FITV but the newer tegs have them. </TD></TR></TABLE>
The newer Integras actually do not have them, and I think 96 or 95 and down do. A FITV would cause the idle to go up and down and do weird things, but not cause it to steadily sit at a high rpm.
AlphaKennyWun
Jan 20, 2012 11:37 PM
srburk
May 21, 2008 10:28 AM
blucrx
Sep 11, 2006 08:36 PM
gray_civic_coupe
Nov 25, 2005 04:57 AM
mdj_ge
Jul 18, 2004 08:31 PM
