stainless steel braided clutch line? wtf
yeah all my drivetrain is stock, but i was thinking that the line would send the driver more feedback from the clutch.. cuz it wont be "spongey".
well in what application would this be a good mod?
It would be a good appliccation in a shaved engine bay where you're trying to eliminate hardlines. A hardline will always give a more positive feel, because there is zero flex.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">so are you saying the stainless steel clutch line will "flex more" compared to the metal piece of tube in the OE.... and this would be worse, or what?</TD></TR></TABLE>
Yes, they would flex more, and yes, this is bad. The line flexing in diameter reduces pressure. Less pressure = less positive feel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">then WTF, why do people even make them and call them an "upgrade"?</TD></TR></TABLE>
They're a cosmetic upgrade.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">They're a cosmetic upgrade.</TD></TR></TABLE>
aight, that pretty much sums it up... and im not getting one
The only "upgrade" you need is this
replaces the rubber hose piece that the hard line has
off topic a little bit but also worth while changing out your brake lines too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 »</TD></TR><TR><TD CLASS="quote">
off topic a little bit but also worth while changing out your brake lines too!</TD></TR></TABLE>
is this the one from fastline performance? I have that one and it did the job perfectly.
X2 --- I was waiting for someone to say that....
off topic a little bit but also worth while changing out your brake lines too!</TD></TR></TABLE> :
if you look at the rubber clutch like, its very weak and easy to squeeze and stuff, thus flexing alot under pressure (clutch). if you replacae it with a SS line, it wont nearly flex as all, giving a more responsive clutch feel.
just my .02 but i used that line with my rps stage 4 pressure plate and after 6mo the line exploded in the center.. i made my own hard line with plenty of flex left for it, problem solved..
yeah i have to say the best bet would be to use ss hardline the whole way to the slave but b/c the engine has to move, they use a rubber hose but really there are many people that use ss braided lines the whole way and do not have problems. It looks much better and then u can hide the line where ever you want and not have the ugly greenish hardline on your fire wall. Cleans things up asthetically and functionally by getting it out of the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">yeah, so im gonna get one... i dont think earn knew what he was talking about. no offense.</TD></TR></TABLE>
I knew my tech, I just didn't know the part you were talking about. I've seen many a person replace all their hardlines with ss braided line when they're doing engine bay tucks.
I knew my tech, I just didn't know the part you were talking about. I've seen many a person replace all their hardlines with ss braided line when they're doing engine bay tucks.</TD></TR></TABLE>
yea i would agree that the WHOLE replacement ss line that the people who are doing tucks in my opinion are a waste of money and MAY no proof offer a little bit of flex then the greenish hard line honda put on there BUT having said that in my opinion from a performance standpoint ALL you need is the ss line i depicted nothing more nothing less because that rubber hose your going to replace or SHOULD replace with the SS is the bottle neck or weak point in the system nothing
else!
ALSO there is a website that i have also ordered from for friends ss lines weather it be brake or clutch that are cheaper then any other website i know of for example SS clutch line here is only $25
check it out.......
http://www.boneheadperformance.com/
else!
check it out.......
$25 shipped SS clutch line!
http://www.boneheadperformance...s.htm
SS brake lines $80
http://www.boneheadperformance...honda
can't beat that price
SS brake lines $80
what a lotta people forget is their are diferent types of " s.s braided " line make sure you use the teflon lined ss braided the reg ss rubber lined braided will be worst then stock
