91 integra swap, problems
my friend has a problem with his 91 integra swap(swap with a 2000 gsr motor)
now his car was not professionally done the clean way, more rig then clean his problems went from a oil leak in the valve cover gasket, and the distributor which did not give spark to the wires and plugs, we replaced and thought that would be the problem, oh yeah also changed the fuel filter and so we try to start it and it sounds as if it wants to go but no dice.now my question is, is it possible since it leak alot of oil could've clog the piston or for some reason just wont allow it to start up and go?
