o2 sensor on 88 si
Old May 22, 2002 | 02:40 PM
fastcrxs1's Avatar
Default o2 sensor on 88 si
i know that on most hondas the o2 sensor is located on the header. it usually has a few wires and one is the signal wire. well my problem is that, i was hooking up my a/f gauge when i noticed that what appears to be my o2 sensor only has one wire. i didn't want to hook it up because i question if it is the right wire. so your input would be helpful.
Old May 22, 2002 | 02:41 PM
EP3_05's Avatar
Default Re: o2 sensor on 88 si (fastcrxs1)
Correct...pre-1992 cars have a single wire O2 sensor. Hook it up and you will be fine
[Modified by 91civic, 6:41 PM 5/22/2002]
Old May 22, 2002 | 02:45 PM
fastcrxs1's Avatar
thanks for the help !
Old May 22, 2002 | 03:57 PM
976's Avatar
976
New User
The o2 sensor you are talking about is the EGR valve, not o2 - correct?
The proper o2 sensor would be before the cat right? I am currently setting up an A/F gauge myself, getting a little confused since I have a JDM B20A, different setup from the USDM.
astroxtc
Dec 13, 2006 12:57 PM
LsTurbo91
Oct 8, 2001 09:20 PM
