96 GSR snapped timing belt
Old Mar 8, 2007 | 05:24 PM
hifonics's Avatar
Default 96 GSR snapped timing belt
hi am new too this site i got a 95 civic with a 96 GSR swap i snapped a timing belt a while back have'nt pulled the head yet but i don't no whats cheaper too just replace the whole head with a reman or change the vavles i can get a head for 400 but if it's cheaper too replace the vavles what kind should i get? thanks for ur help guys
Old Mar 8, 2007 | 05:39 PM
Sweetsystem's Avatar
Default Re: 96 GSR snapped timing belt (hifonics)
400 bucks for a clean rebuilt GSR Head sounds better than repairing 100-200 bucks worth of parts. Plus Time, Plus no warranty, plus dirty head that had been partially repaired without new valve seats. But I have no experiance rebuilding or repairing a head anyways.
Where are you getting this $400 rebuilt head?
Old Mar 8, 2007 | 06:00 PM
willywong's Avatar
where the heck are you getting a remanufactured GSR head for $400?? and you have to do a little more than just head work if you snapped your timing belt.
Old Mar 8, 2007 | 06:33 PM
hifonics's Avatar
am getting it from ADC there sites down right now but thats the price one of there tellers gave me with a 1 year 20,000 mile warranty but what else wood i have too do other the switch out the head?
Old Mar 8, 2007 | 06:59 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Are you automatically assuming that you messed the head up,
or Do you know for a fact that you bent valves, or did other damage?
You can sometimes get away with nothing happening, and just replace the belt.
Old Mar 8, 2007 | 07:58 PM
hifonics's Avatar
Default Re: 96 GSR snapped timing belt (Sweetsystem)
well i know it's a interference motor and from what people have told me there's a 5% chance that it's just the belt but i don't no for sure the heads still on the motor
Old Mar 8, 2007 | 08:36 PM
teggy182's Avatar
first things first gotta get that head off and look at the(if there is any) damage.
Old Mar 8, 2007 | 08:59 PM
__oversea's Avatar
do the leak down test. it will tell you what or how many vlaves are bent.
Old Mar 9, 2007 | 12:55 AM
suzawa94's Avatar
Default Re: 96 GSR snapped timing belt (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">Are you automatically assuming that you messed the head up,
You can sometimes get away with nothing happening, and just replace the belt.</TD></TR></TABLE>
ditto. do a compression test or if you have access to shop air a cylinder leakdown test. chances are since most honda motors are interference motors, your valves are probably bent. you should atleast verify which cylinders are bad and then see how much valves are bent.
Old Mar 9, 2007 | 12:57 AM
suzawa94's Avatar
Default Re: 96 GSR snapped timing belt (Kangpreza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangpreza &raquo;</TD></TR><TR><TD CLASS="quote">do the leak down test. it will tell you what or how many vlaves are bent.</TD></TR></TABLE>
a leak down test will not tell you how much valves are bent. it will tell you whether the intake or exhaust valves are bad in this situation
Old Mar 9, 2007 | 04:03 AM
adamrich33's Avatar
Default Re: 96 GSR snapped timing belt (suzawa94)
i have snapped 2 timing belts on 2 different cars and came out alive, it is worth spending 40 bucks on a new belt and try to get your remaining head to work, your going to be buying a new belt anyways
Old Mar 9, 2007 | 09:53 AM
iUsedToBeFast's Avatar
Default Re: 96 GSR snapped timing belt (adamrich33)
i snapped 3 belts on 3 cars in the past 2 years and nothing was wrong with the heads 1 b16 an lsvtec and a gsr
Old Mar 10, 2007 | 07:03 PM
peoriasfinest90's Avatar
Default Re: 96 GSR snapped timing belt (iUsedToBeFast)
i personally have never snapped a belt but 2 of my buddies have n they got fu**ed. Pray for the best...thats all i can say.
Old Mar 10, 2007 | 07:33 PM
Default Re: 96 GSR snapped timing belt (peoriasfinest90)
compression test the motor and if its good your all set
stockF22B1
Dec 15, 2012 07:08 PM
modernvisionscc
Aug 3, 2007 12:06 PM
boostin4door
12
Jan 25, 2005 09:36 AM
civicguy
Jan 23, 2002 06:47 PM
