Anyones door locks ever freeze? (power locks DC4)
I go to the car wash today, and everything works fine.
it got colder out (~21 degrees right now...) and now my driver side door won't LOCK. As in, its stuck unlocked... opens and closes fine - no other problems.
I hit the unlock on the keyless and it makes a rapid click-click-click-click when i try to <U>lock </U>the door. When I try to unlock the door, it clicks once as usual and sounds normal. But then I hit it again to try to lock it and same thing: clickclickclickclickclick!
I tried the key - key goes in, and you can turn it both ways, but it won't allow me to lock the door. Not with the key, not by hitting the switch on the inside of the door, and not by the keyless entry....
Also, while openning the door from the inside, the handel feels almost like it not connected to anything... Perhaps somethin inside my door is stuck/broke???
What should I do? is it just frozen? is it broken? Anyone have experaince with this? (DC4 w/ power locks....)
I'm gonna take the door panel off tommorow and spray soem de-icer or WD40 or seomthing and see whats wrong - but for now I guess ill just take my radio/sub inside for the night...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jorge59la »</TD></TR><TR><TD CLASS="quote">i had the same click,click,click going on and i took it to the dealer and they replaced the little door lock motor.</TD></TR></TABLE>
Dam I hope its not the motor... I hope its just frozen - Only reason I suspect it is is that I went to teh car wash - then the temp drops below freezing...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin_teg »</TD></TR><TR><TD CLASS="quote">buy the **** that unfreezes door locks from autozone, worked on my girls gst. Its small enough to fit in your purse too haha </TD></TR></TABLE>
yeah ill try that unfreezing stufff tommorow, ill let you know if it works... and if it fits in my purse
yeah my power locks seem to be getting old, they wont lock it. they make the little lock nub go like half way in but doesnt lock the door
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phish4709 »</TD></TR><TR><TD CLASS="quote">as long as it's not frozen locked you're all good, atelast you can get in your whippp
Yeah true, but I cant lock it either - at least the alarm will go off if someone opens the door - Then I have 2 seconds to hear the alarm before they disconnect the battery and steal my car
</TD></TR></TABLE>Yeah true, but I cant lock it either - at least the alarm will go off if someone opens the door - Then I have 2 seconds to hear the alarm before they disconnect the battery and steal my car
All better now - Didn't work at first but after a 10 minute drive the locks work fine....
Wierd b/c its still below freezeing - must have been frozen and the vibrations of driving free'd it up... no sporay or anything
Intercooler
Nov 18, 2004 08:43 PM
