best bolt ons for mpg
Old Mar 8, 2007 | 04:12 PM
gildmi's Avatar
Default best bolt ons for mpg
i was wondering if anyone knew the best bolt ons that cause better gas mileage or do not detrement gas mileage while gaining power? i have a 98 civic dx with a stock D16Y7
Old Mar 8, 2007 | 04:19 PM
JKov240's Avatar
Default Re: best bolt ons for mpg (gildmi)
You're not going to see any real improvements (power wise) with bolt-on's...but a good place to start is some form of cold air intake, headers, and an exhaust system...
Old Mar 8, 2007 | 04:20 PM
97civicdx's Avatar
Better gas mileage? Leave it bone stock then.
Old Mar 8, 2007 | 04:41 PM
excivicboy96's Avatar
Default Re: best bolt ons for mpg (97civicdx)
get a d16y5 or d15z1
Old Mar 8, 2007 | 04:45 PM
knockout's Avatar
swap a d16y5 in and you'll be set. vtec-e rocks.
AntiochOG's Avatar
Check out gassavers.org they have lots of info on modifying you car to get the best gas mileage.
Old Mar 8, 2007 | 05:22 PM
shift_slide's Avatar
Default Re: best bolt ons for mpg (AntiochOG)
bolt on a cx transmission and stop driving to hear your car
Old Mar 8, 2007 | 05:44 PM
hondajunkee's Avatar
swap out for a crx hf engine
Old Mar 8, 2007 | 05:46 PM
ekb16's Avatar
put in a tornado
Old Mar 8, 2007 | 05:47 PM
Syndacate's Avatar
Default Re: (hondajunkee)
Skinny *** tires, a D16Y5 w/ a Y5 tranny. Weight reduction. Pull the AC. **** like that.
Old Mar 8, 2007 | 06:47 PM
Boner_Ben's Avatar
Default Re: (Syndacate)
Pull off an injector clip or two
Old Mar 8, 2007 | 07:05 PM
Syndacate's Avatar
Default Re: (Boner_Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">Pull off an injector clip or two </TD></TR></TABLE>
Haha.
Cut a hole in the floor board and Flintstone that ****
God knows, you could probably make over the top 80lb/ft tq. at the wheels w/ ur legs.
EDIT @ OP:
Visit gassavers.org and crxmpg.com
They're into that ****.
Old Mar 8, 2007 | 07:28 PM
highrev1987's Avatar
syn are you best friends with google?
Try a Hot Air Intake
and VTEC-E
Jack up your tire pressure and/or get realy hard compound tires
Old Mar 8, 2007 | 07:41 PM
92ehatch's Avatar
Default Re: (highrev1987)
i have actually noticed a mpg increase one every car ive driven when i installed an intake and k&n filter.
now this only works if you drive normal.
if you like the sound too much and drive like a jack *** street racer then mpg gets worse
Old Mar 8, 2007 | 07:43 PM
MR.johnson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondajunkee &raquo;</TD></TR><TR><TD CLASS="quote">swap out for a crx hf engine</TD></TR></TABLE>
my vtec hits when that motor is at redline.
Old Mar 8, 2007 | 07:50 PM
bacardiboi's Avatar
Default bleh
started with bad MPG and its only gotten worse with allmymods..............
coldtotouch
13
Aug 29, 2005 09:46 PM
Boostage
Mar 16, 2005 03:19 PM
H.crx-si
Feb 11, 2005 03:39 PM
RnEpmc
Jul 11, 2004 01:28 PM
JDM_Type-R
Jul 3, 2004 07:06 PM
