Rear passenger side caliper sticking on my hatch??
Old Mar 8, 2007 | 12:45 PM
91EF_Si's Avatar
Default HELP! Rear passenger side caliper sticking on my hatch??
I just noticed this annoying problem today, I adjusted my e-brake handle and now I notice my rear passenger caliper SOMETIMES sticks. When I'm about to launch normally, I feel the right side holding back and sometimes it makes a weird noise, like if the e-brake was up. I already adjusted the e-brake handle to see if I tightened too hard but it wasn't that. Like I said sometimes it sticks and other times its fine. Any ideas? FYI I have a 93 CX with rear disk conversion.
Old Mar 8, 2007 | 01:30 PM
91EF_Si's Avatar
Default Re: HELP! Rear passenger side caliper sticking on my hatch?? (93LShatchy)
bump
Old Mar 8, 2007 | 01:51 PM
EL Vap133's Avatar
Well if you know it sticks, why not replace the caliper?
Old Mar 8, 2007 | 01:54 PM
BubblegumTate's Avatar
Default Re: HELP! Rear passenger side caliper sticking on my hatch?? (EL Vap133)
If you know it isn't the cable being adjusted too tight, rebuild or replace the caliper. There is a handbrake mechanism in the rear caliper that is probably sticking.
Old Mar 8, 2007 | 03:28 PM
solerizr's Avatar
Default Re: HELP! Rear passenger side caliper sticking on my hatch?? (BubblegumTate)
Check the caliper, check the ebrake mechanism behind the caliper, check the cables, and check the equalizer.
Old Mar 10, 2007 | 03:59 PM
jpaul_martinez's Avatar
Check to see if your caliper bracket sliding pins seized. There are 2 each on the rear. Remove them, clean out the bracket with some WD40 and a wire brush, remove the pins & clean with a wire wheel & grease up then test.
dgdarien
Suspension & Brakes
Apr 7, 2017 05:37 PM
Skidoorcng
Honda Civic (2006 - 2015)
Jun 1, 2015 09:14 AM
mhart
May 14, 2009 05:24 PM
Panoply
Aug 4, 2006 07:16 AM
PreludePhill
Apr 28, 2006 06:37 PM
