LS rod bolt installation ?
Old Mar 8, 2007 | 11:29 AM
red-teg!'s Avatar
Default LS rod bolt installation ?
I can change my rod bolts by just dropping my oil pan right?
Old Mar 8, 2007 | 11:45 AM
unknown0001's Avatar
Default Re: LS rod bolt installation ? (red-teg!)
no, they have to be pressed out by a machine shop
Old Mar 8, 2007 | 12:48 PM
Blackturboteg's Avatar
Default Re: LS rod bolt installation ? (Mr.RHTuner)
why do you need a machine shop to press them out. I have had friends that change rings and rods and **** like that with no machine help . And if u can turn the crank moving the pistons with a socket.
Old Mar 8, 2007 | 12:54 PM
doood's Avatar
been there done that
Default Re: LS rod bolt installation ? (Blackturboteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackturboteg &raquo;</TD></TR><TR><TD CLASS="quote">why do you need a machine shop to press them out. I have had friends that change rings and rods and **** like that with no machine help . And if u can turn the crank moving the pistons with a socket.</TD></TR></TABLE>
because the stock rods uses a stud and nut. after pressing the studs out and installing the bolts, you still need to have the rods resized. unless you have all these machines in your garage, take it to a machine shop.
Old Mar 8, 2007 | 12:59 PM
Default Re: LS rod bolt installation ? (doood)
K thanks just was wondering because i know people that have done it there self just was curious. Wasnt saying u were wrong just want a answer
Old Mar 8, 2007 | 01:16 PM
Because the piston rods have the rods pressed in. Piston rings aren't pressed in, they just slide onto a piston so that's a completely different job and much easier aswell.
Canadian_EF
Oct 9, 2013 03:36 PM
egvtec
Dec 12, 2005 03:49 PM
boosted k20
Mar 31, 2005 01:26 AM
boosted k20
Mar 28, 2005 09:17 PM
GTWITIT
Feb 22, 2005 06:35 AM
