steering wheel instalation
ok i baught a 84-87 crx steering wheel with hub but i did not look at the year and i have a 89 crx so i tried it on any ways and it fits but the steering wheel is not straight i need help to align it.or someone tell me if it is not possible?
If you have *****, the best way to do it is drive around the block (With low traffic) with the nut off and take it off and put it back on the splines with it straight. Keep doing it till it's perfect. Then tighten that nut up and you're golden like a shower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil »</TD></TR><TR><TD CLASS="quote">If you have *****, the best way to do it is drive around the block (With low traffic) with the nut off and take it off and put it back on the splines with it straight. Keep doing it till it's perfect. Then tighten that nut up and you're golden like a shower.</TD></TR></TABLE>
you're frickin' nuts man.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
you're frickin' nuts man.....</TD></TR></TABLE>
Nah, it works great. Like I said, only if you have ***** & on slow streets. When I align older VW's and Honda's, it's the easiest way to go. To get it right on.
you're frickin' nuts man.....</TD></TR></TABLE>Nah, it works great. Like I said, only if you have ***** & on slow streets. When I align older VW's and Honda's, it's the easiest way to go. To get it right on.
TeamRiskEG6
15
Apr 9, 2008 03:49 PM
kantfadedisazn
Dec 23, 2005 08:40 PM
