IACV
My swap had the same idle problems after I did it. Took me days to figure out what's going on. But I'd suggest making sure there's not cel codes and then reset the ecu. After I did that the engine ran as perfect as when we took it out of the donor car. I still consider myself new to swaps, but can somebody conferm that a p28 would or wouldn't work in his situation? Also blocking off your iacv? are you mad?!? jk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R »</TD></TR><TR><TD CLASS="quote">my idle is jumping from 1,000 to 2,000 rpm with the p28 ecu and obd2-1 conv harness. because off the 3 wire and 2 wire mixup</TD></TR></TABLE>
Is there any way that you can use the 3-wire or do you have to switch to a 2-wire to run OBD1 ECU?
Thanks
Thanks
Chris N
Dec 4, 2003 09:40 AM
