turbos
Old Mar 8, 2007 | 09:35 AM
dkrex001's Avatar
Default turbos
what would be a good turbo for a D16Z6
fast spool and around 10 psi
the motor is all stock
Old Mar 8, 2007 | 09:40 AM
JustAnotherRex's Avatar
Default Re: turbos (dkrex001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 &raquo;</TD></TR><TR><TD CLASS="quote">what would be a good turbo for a D16Z6
the motor is all stock</TD></TR></TABLE>
Thumper T-106
http://www.turboneticsinc.com/turbo_thumper.htm
Best bang for your buck, and its upgradable!
(I like sentences and capitalization. Check out used Saab or Volvo turbos, small t25 type things would do well is my understanding)
Old Mar 8, 2007 | 10:18 AM
89efDUSTY's Avatar
t25 ...but at 10 psi regardless of the turbo i would start changing internals first
read maximum boost by Corky Bell...good stuff
Old Mar 8, 2007 | 10:54 AM
dkrex001's Avatar
Default Re: turbos (89efDUSTY)
well i know a guy that has a D16Z6 and is push like 8psi
and i have heard of people running around 15 psi on a stock motor for years and if they can i can run 10psi
Old Mar 8, 2007 | 11:02 AM
gator88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 &raquo;</TD></TR><TR><TD CLASS="quote">well i know a guy that has a D16Z6 and is push like 8psi
and i have heard of people running around 15 psi on a stock motor for years and if they can i can run 10psi</TD></TR></TABLE>
all in the tuning... without a tune,the smallest psi of boost is far from the best for your motors health.
Autoworks's Avatar
Don't get caught up on a PSI number, it means nothing really. 10psi on a T25 doesn't equal 10psi on a 60-1 when it comes to whp#s.
How much power are you wanting to make?
Old Mar 8, 2007 | 11:05 AM
dkrex001's Avatar
Default Re: turbos (Autoworks)
around 225 hp
Old Mar 8, 2007 | 11:07 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 &raquo;</TD></TR><TR><TD CLASS="quote">around 225 hp</TD></TR></TABLE> then t25 at 10...but what kind of management system will you run?
Old Mar 8, 2007 | 11:14 AM
Autoworks's Avatar
T3/T4 50 trim or T3 super 60
Old Mar 8, 2007 | 11:15 AM
ILcrxsi1's Avatar
I tell doctors what to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">
T3/T4 50 trim or T3 super 60</TD></TR></TABLE>I agree
Old Mar 8, 2007 | 11:16 AM
awdgsx96's Avatar
Yeah, your def going to need something bigger than a t-25. It will def run out of breath before 225 whp
Old Mar 8, 2007 | 11:26 AM
dkrex001's Avatar
Default Re: turbos (awdgsx96)
i will run crome or hondata
Old Mar 8, 2007 | 11:45 AM
dkrex001's Avatar
what about t3/t4 60 trim
i do not know turbos so what does the trim mean
Old Mar 8, 2007 | 11:51 AM
awdgsx96's Avatar
Go to http://www.turbobygarrett.com
It has a very good turbo information page. It has Turbo Tech 101, 102, and 103 haha. But yeah, check it out and it will cover just about everything. You'll find that trim is: Trim is a term to express the relationship between the inducer* and exducer* of both turbine and compressor wheels. More accurately, it is an area ratio.
This is in the very beginning of 102.
Old Mar 8, 2007 | 11:54 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 &raquo;</TD></TR><TR><TD CLASS="quote">what about t3/t4 60 trim
i do not know turbos so what does the trim mean</TD></TR></TABLE>
No, not a 60, I just put together a setup this morning using a 60 trim on a "mild" H22 setup.
A 50 trim is a nice match for the stock SOHC. A super T3/60 is as well.
Old Mar 8, 2007 | 11:59 AM
Tippyman's Avatar
A 50 trim is a nice match for the stock SOHC.</TD></TR></TABLE>
which is why I bought one.
Old Mar 8, 2007 | 01:33 PM
racing_reject_001's Avatar
Default Re: turbos (Tippyman)
ok im kinda laughing at this guy i talked to maybe someone can back him up on this with proof now i dont even belive it but this guy told me a jdm b16a with cams valve train and a mitsubishi eclipse turbo will pull agenst and smoke a corrvette z06.....now im a huge honda fan but i just cant see that happening
Old Mar 8, 2007 | 05:54 PM
Autoworks's Avatar
Default Re: turbos (racing_reject_001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing_reject_001 &raquo;</TD></TR><TR><TD CLASS="quote">ok im kinda laughing at this guy i talked to maybe someone can back him up on this with proof now i dont even belive it but this guy told me a jdm b16a with cams valve train and a mitsubishi eclipse turbo will pull agenst and smoke a corrvette z06.....now im a huge honda fan but i just cant see that happening </TD></TR></TABLE>
You made that up yourself didn't you...
Old Mar 8, 2007 | 07:47 PM
Tippyman's Avatar
B16's own all.
IBTL.
Old Mar 8, 2007 | 08:28 PM
mra4886's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">T3/T4 50 trim or T3 super 60</TD></TR></TABLE>
i agree too. and run crome if your obd1. will provide real quick spool and good whp.
Old Mar 9, 2007 | 06:24 AM
civhatch90's Avatar
You made that up yourself didn't you...</TD></TR></TABLE>
didnt you hear about the super b16a's? where have you been?
Old Mar 9, 2007 | 11:05 AM
Default Re: turbos (civhatch90)
i didint make that up im not the stupid i still find it hard to believe......now me id build the hole damn engine so i could run a good size turbo and not blow the engine sky high but trust me even tho i hate the corvette im not saying impossible dumb stuff like that
Old Mar 9, 2007 | 11:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing_reject_001 &raquo;</TD></TR><TR><TD CLASS="quote">I made that up. I am that stupid. I still find it hard to believe, now I would build the whole damn engine so I could run a good sized turbo and not blow the engine sky high. Trust me, even though I hate the Corvette I'm saying nearly impossible dumb stuff like that.</TD></TR></TABLE>
I have my issues with your ability to build a car that would actually perform better than a Z06, since you have issues with grammar and spelling. Maybe you're capable, but I edited your post to make it more legible for everyone else.
Bench racing FTL.
Old Mar 9, 2007 | 12:18 PM
Default Re: turbos (JustAnotherRex)
yea thats funny......why did u do that i didnt do or say nething to u that gave u the right to do that now all i wanna know is was that guy nuts or is it actually possible?
Old Mar 9, 2007 | 07:04 PM
gator88's Avatar
wanna hear a joke about nuts? (yes the guy is nuts)
what do you call nuts on a wall?.......walnuts
what do you call nuts on a chest?.........chestnuts
what do you call nuts on a chin?.........dick in mouth
sorry, had to break out the old ones for some dumb reason
