Driver's window slips out of track because there is too much play in the window
Old Mar 8, 2007 | 08:09 AM
WhiteOnRice's Avatar
Default Driver's window slips out of track because there is too much play in the window
My driver's side window always "leans" forward and slows way down, usually stopping because there is too much friction. If I don't hold the top of the glass and push it back (to avoid the leaning) while it's rolling up there is about a 0.5 inch gap that I can fit my finger in.
When the window is halfway rolled up I can move it forwards and back almost an inch but there are no loose bolts and the regulator is new. Why is there is much play?
I've heard I need to replace the runners. What parts would I need?
Here is a picture https://www.hondapartsdeals.co...7.gif
Old Mar 8, 2007 | 09:03 AM
Twixle's Avatar
ate my pixel
Default Re: Driver's window slips out of track because there is too much play in the window (fizix_skate)
are you sure that both of the bolts on the regulator are tight? I doubt you'd be able to move it that much if they were. maybe try unbolting it, rolling it all the way up so it's closed correctly, and then re-tightening the bolts.
Old Mar 8, 2007 | 03:32 PM
hondadude's Avatar
have you tried adjusting the bottoms of the run channel towards the glass? Tighten it up so to speak.
Be sure to lay the silicone lube into the run channel
Viperoholic
Jan 24, 2013 11:32 AM
TwoKSiR
Nov 4, 2007 02:33 PM
tx95excoupe
11
Sep 14, 2007 05:43 AM
00ekcoupe
13
Aug 27, 2005 10:52 AM
Devilry
Nov 22, 2004 07:35 PM
