89 D16z6 surgine issue
i have a 89 civic converted to obd1 and mpfi it has a D16Z6 and my question is this. evertyime i drive it, it drives fine no problems but when i come to a stop my rpms start to fluctuate (spelling) but only for about a min. wat could be causing this. ive already ruled out that it might be the IACV, so im searing the junkyards for another one. thanks
Have you tested the iacv? Also did you have the throttle body unbolted from the head? I had a surging problem and it turned out to be the throttle body gasket. Check your gaskets, vacuum lines, connection, basically do a thourough visual inspection
jdmstockeg6
Sep 10, 2007 08:49 PM
stwano
Jul 9, 2006 12:04 PM
OnebadJdmEg6
Jan 20, 2004 04:26 PM
