LS engine in del sol
Old Mar 7, 2007 | 10:34 PM
Synbios's Avatar
Default LS engine in del sol
I have a '94 LS teg engine in a '95 del sol Si. I was just wondering what RPM I should be shifting at (for max hp, when racing). My instrument cluster is stock. What is the redline of the LS engine, is that what I should shift at?
There's probably a ton of info on this and I haven't searched yet, but what exactly do I need to do an LS/VTEC? I realize I need a "gsr head" but when looking on craigslist I see various packages and I'm not sure what components I need exactly. I need a GSR ECU in order to use the VTEC correct? What else?
Old Mar 7, 2007 | 10:44 PM
exotik4doorcivic's Avatar
Default Re: LS engine in del sol (Synbios)
redline is 7200 same as d series
you can you a b16 or b18c head the b16 is better though
you will need a b16/b18c oil pump and this setup has been done to death so they have kits like golden eagle now that you can buy it comes with the oil line for vtec head gasket and the dowel pins
http://www.intecracing.com < kit here under specials
also you might want to think about re building your bottom end for reliablity
Old Mar 7, 2007 | 10:49 PM
Synbios's Avatar
Default Re: LS engine in del sol (exotik4doorcivic)
I still have the original Si engine.
So I can take the b16 vtec head off my old sohc vtec Si engine and put that on the LS engine to get dohc vtec?
I didn't know that fits..
Old Mar 7, 2007 | 10:54 PM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synbios &raquo;</TD></TR><TR><TD CLASS="quote">I still have the original Si engine.
I didn't know that fits..</TD></TR></TABLE>
no.. b series and d series a diff ball game..
ridin98civic's Avatar
it doesnt. a del sol si motor and a civic si motor from 99-00 are completely different. your si motor is a d series.
edit: ahh you beat me to it
Old Mar 7, 2007 | 11:00 PM
Synbios's Avatar
oh b16 is dohc only, d16 is sohc mostly. just tryn to get used to this honda lingo. I come from a background of mazda's and rotaries.
If I got a b18c or b16 head, I should still be shifting at 7200RPM right? what do you recommend I do to reinfoce my bottom end to increase the redline to whatever the b18c and b16 engines go to? I don't really want to swap in a whole new gsr engine. too expensive and time consuming.
Old Mar 7, 2007 | 11:15 PM
Default Re: (Synbios)
stock redline for a b18c/b16 is 8200 with that head youre able to take it that high, but when you start building your head with better cams/springs/retainers you can take it higher if you get your ecu tuned
just do your research lsvtec has been covered millions of times so you wont have trouble looking for info
Old Mar 7, 2007 | 11:17 PM
I don't really want to swap in a whole new gsr engine. too expensive and time consuming.</TD></TR></TABLE>
if you really want some power out of that ls you can turbo it depending on the mileage and get more power than a gsr
Old Mar 13, 2007 | 03:08 PM
gsrdelly's Avatar
Default Re: (exotik4doorcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">
if you really want some power out of that ls you can turbo it depending on the mileage and get more power than a gsr</TD></TR></TABLE>
i personally would rather do a ls vtec then ls turbo... but then again i'd end up turboing it anyways so bottom line vtec is necessary
Steve86
Jul 10, 2003 09:27 AM
96tegra
Jul 7, 2003 07:55 PM
nitecrook
Jul 26, 2001 04:35 AM
