GSR all motor/nitrous build
Old Mar 7, 2007 | 08:05 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default GSR all motor/nitrous build
I'm almost finished gathering everything for my GSR build.. i'm gonna be using GSR block and head..
HEAD:
supertech springs/retainers
ferrea 1mm oversized intake, ferrea stock exhaust valves
stock cams for now/ AEM 3 bolt cam gears
edolbrock victor x mani
professional products 68mm satin tb
mild port and polishing/3 angle valve job
bpi flow stack
hytech tri-y replica
Block
fully balanced rotating assembly
eagle H-beam rods
Wiseco 11:8 pistons..
GE oil block offs.
new oem gsr water pump/timing belt
ARP headstuds
Exedy stage 1 clutch
fidanza street light flywheel
ARP flywheel bolts
i'm shooting for around 190 WHP on the motor and around 280-300 with the spray..
anyways, am i missing anything?.. should i get ARP headstuds and and mainstuds? or just headstuds?..
comments and advice is greatly appriciated
Modified by ohsnapzafingcu at 9:24 PM 5/2/2007
Modified by ohsnapzafingcu at 11:03 PM 7/3/2007
Modified by ohsnapzafingcu at 11:05 PM 7/3/2007
Modified by ohsnapzafingcu at 11:07 PM 7/3/2007
Old Mar 7, 2007 | 09:28 PM
j spec's Avatar
Default Re: GSR all motor/nitrous build (ohsnapzafingcu)
arp headstuds are highly recommended if not necessary. Main studs are not necessary at all.
Also no way that thing will make 190whp with a gsr intake and throttlebody ditch it in favor of a single plenum design as well as a larger throttle body. Also invest in a good quality header.
good luck
Modified by j spec at 11:04 PM 3/7/2007
Old Mar 8, 2007 | 02:11 AM
Richard...'s Avatar
Default Re: GSR all motor/nitrous build (j spec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j spec &raquo;</TD></TR><TR><TD CLASS="quote">arp headstuds are highly recommended if not necessary. Main studs are not necessary at all.
good luck
Modified by j spec at 11:04 PM 3/7/2007</TD></TR></TABLE>
blox intake manif can be had for cheap!
Old Mar 8, 2007 | 10:49 AM
Default Re: GSR all motor/nitrous build (richard7968)
Thanks for the reply guys! Especially about the arp bolts.. I'm just gonna probably run stock intake mani and tb for now. Unless I can find a combo for really cheap.. I don't really mind what the power is off the motor cuz the n2o will make up for it..
But upgrades don't hurt
Old Mar 8, 2007 | 11:21 AM
B18cHatch06's Avatar
should be a fun build...i have a similar set-up...11:1-11:3.1 compression pro1 cams good bolt-ons aka RMF header and made 190whp not finished with the tune..still need to adjust cam gears/bpi flowstack n run the bitch open header..oh and also have a direct port on it..havnt tuned it yet though..looking to make about 300whp on bottle
Old Mar 8, 2007 | 03:22 PM
Default Re: GSR all motor/nitrous build (B18cHatch06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18cHatch06 &raquo;</TD></TR><TR><TD CLASS="quote">should be a fun build...i have a similar set-up...11:1-11:3.1 compression pro1 cams good bolt-ons aka RMF header and made 190whp not finished with the tune..still need to adjust cam gears/bpi flowstack n run the bitch open header..oh and also have a direct port on it..havnt tuned it yet though..looking to make about 300whp on bottle </TD></TR></TABLE>
Oowie that sounds good.. I just wanted cams so I could make power after 8 grand... and I wish I woulda just gone with a direct port setup and done like a 150 shot. That would be sickk! But a 75-100 shot for now is goood nuff'.. This is my first motor and first time to ever experiment with nitrous.. I have lots more to learn
I still gotta wait 2 months to get my licence &gt;_&lt;
Old May 2, 2007 | 01:37 PM
bumppp with updates, i'm waiting for my valvetrain to come in and my headgasket.. then everything is off to the shop!
Old Jul 3, 2007 | 10:08 PM
ttt..
i just got my motor back yesterday!
Modified by ohsnapzafingcu at 4:11 PM 9/18/2007
Nickb257
Northeast (Sales)
Sep 4, 2011 08:18 AM
Nickb257
Northeast (Sales)
Aug 23, 2011 04:18 AM
Nickb257
Aug 23, 2011 04:15 AM
SwIntegraB16
Jan 19, 2008 04:23 AM
DC2_ALL MOTA
Aug 10, 2006 10:00 AM
