H22 swap into manual 6th gen (98-02) accord
Old Mar 7, 2007 | 07:50 PM
jfboy's Avatar
Default H22 swap into manual 6th gen (98-02) accord
The FAQ page doesnt work. I have a 98 accord sedan with manual transmission and the SOHC vtec engine. I would like to run an h22 (maybe even an h23). I have to retain OBd2 compliance.
Any tips or links ?
What are the best donors (I'm guessing 97-01 ludes)
What mounts do I need ?
What ecu and wiring harness.
(I know I can keep my old tranny)
Also will the h22 head bolt to my bottom end?
I have done many swaps (h22 in 92 S lude and countless b-series into civics) but this is my first time dealing with this generation accord.
thank you guyz!
Old Mar 7, 2007 | 08:00 PM
accordinglyevil's Avatar
you might find the info in this thread useful. http://www.everything-honda.co...=3843
Old Mar 7, 2007 | 08:26 PM
jfboy's Avatar
Default Re: (accordinglyevil)
looks like he converted to OBD1 and used a jdm motor. I have to keep mine obd2 compliant.
Old Mar 8, 2007 | 12:50 PM
XiOus271's Avatar
Default Re: (jfboy)
I am sure that as long as you have an OBD2 donor car, the swap shouldnt be much different from the ones outlined in the FAQs.
Old Mar 8, 2007 | 02:31 PM
Accord2k-Hybrid's Avatar
Default Re: H22 swap into manual 6th gen (98-02) accord (jfboy)
the only way I know of doing it is by converting to OBD1, the way that the preludes pull information off of the key is different than an Accord for starters, you're going to have to do a whole lot of wiring diagram studying and finding ways to backwards engineer the 2 to work with eachother, if you find a way to keep OBD2 on a 6th gen I would love to hear about it.
Old Mar 9, 2007 | 04:17 AM
XiOus271's Avatar
Default Re: H22 swap into manual 6th gen (Accord2k-Hybrid)
Find the 1996 ECU, its OBD2 and has no immobilizer. If you don't feel like doing that, the dealership has the ability to reprogram the key, but I do not know how much or how likely they are (since some are jackasses) to do it for you.
Old Mar 20, 2007 | 09:55 PM
4drH22Accord's Avatar
I have a 2000 Accord 4dr with a H22A. You can get a P28 ecu and chip it with Hondata and use the Hondata jumper harness like I did. Yes, you can use your stock tranny. Also all the other pieces (ie alternator, a/c, starter etc.)
You need to get a new motor mount for the driver side or have one made. It is a pretty easy swap otherwise.
You can use any year from 92 up also. I have a 92 J-Spec Prelude motor. I think its 92-96 it OBDI and 97-00 is OBDII. Probably wrong on the OBDII years.
Old Mar 21, 2007 | 12:53 AM
philadd's Avatar
Default Re: H22 swap into manual 6th gen (4drH22Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drH22Accord &raquo;</TD></TR><TR><TD CLASS="quote">I think its 92-96 it OBDI and 97-00 is OBDII. Probably wrong on the OBDII years.</TD></TR></TABLE>
96+ is OBDII.
97+ has the immobilizer.
Old Feb 16, 2012 | 09:34 PM
newtonh22's Avatar
Guys I got a 1999 accord ex with a 2001 jdm h23a swap, and I need the wiring diagram so I can connect the distributor to the crank position sensor plug. Please help and thanks
TheRedEM1
Apr 25, 2009 07:56 PM
DCFIVER
Dec 10, 2006 07:39 PM
Katman
Oct 21, 2004 04:50 PM
-Bionic-
Apr 20, 2004 04:07 PM
Nathan007
Mar 29, 2004 11:27 PM
