fluid flush
Old Mar 7, 2007 | 07:39 PM
whiteboy03si's Avatar
Default fluid flush
What does a fluid flush consist of? I want to change out all my fluids, flush the tranny, flush the radiator, ect... What all fluids do i need to replace?? Is there a link someone knows of for a walk through of what im trying to do.
Old Mar 7, 2007 | 07:46 PM
Projekt_2nr's Avatar
Default Re: fluid flush (whiteboy03si)
fluid flush is just replacing all the liquids, but if you do a fluid flush i'd suggest doing also seafoaming the motor
Old Mar 7, 2007 | 07:48 PM
95ProjectEJ1's Avatar
Default Re: fluid flush (Projekt_2nr)
And if you are going to seafoam, make sure its time to do an oil change too. I belive there is something called Auto-Rx for transmission flushes too.
Old Mar 7, 2007 | 07:51 PM
Default Re: fluid flush (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">And if you are going to seafoam, make sure its time to do an oil change too. I belive there is something called Auto-Rx for transmission flushes too. </TD></TR></TABLE>
Old Mar 7, 2007 | 07:54 PM
allricedout's Avatar
do you really think a "flush" is nessecary? cuz i just changed all mine (MTF,10w30, and premixed coolant)
Old Mar 7, 2007 | 08:00 PM
Default Re: (allricedout)
yea i did the seafoam today, i got the oild and the rest of the fluids planned for tomorrow. So just changing radiator fluid would be fine, i dont have to flush it out.
Old Mar 7, 2007 | 08:03 PM
Default Re: (whiteboy03si)
you can flush that with water if it's not going to be cold tomorrow, just drain it and run water in it for about 10min's and then drain the water and fill with coolant
baiwldrnner
Honda Civic (2001 - 2005)
Jul 18, 2007 09:55 PM
H22CD
Apr 21, 2006 08:16 AM
CivicRaping
Mar 20, 2005 06:49 AM
hotstuffjsn
Feb 21, 2005 10:27 AM
TopNotchR
Sep 24, 2004 06:50 PM
