taking b18c1 head off this weekend...suggestions? inputs? insights? do n donts?
Old Mar 7, 2007 | 05:22 PM
shifts's Avatar
Default taking b18c1 head off this weekend...suggestions? inputs? insights? do n donts?
its gonna b my first time taking a head off but i have my friend helpin me who has done it multiple occassions w/a d series. just wondering if nebody has ne insights (specific order in takin off bolts etc) i should know before hand or even a step by step how to n all that good stuff. reason for taking it off is to have it milled n 3angle valve job done to it. while its off we plan to replace dizzy, headgasket, timin belt/water pump, n install arp head studs. thanks in advance! n yes ive used the search n no helms manual for me unfortunately .
Old Mar 7, 2007 | 05:45 PM
Boostedb20EH2's Avatar
Default Re: taking b18c1 head off this weekend...suggestions? inputs? insights? do n donts? (shifts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shifts &raquo;</TD></TR><TR><TD CLASS="quote"> no helms manual for me unfortunately .</TD></TR></TABLE>
http://www.hondahookup.com
Old Mar 8, 2007 | 05:54 AM
shifts's Avatar
Default Re: taking b18c1 head off this weekend...suggestions? inputs? insights? do n donts? (Boostedb20EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hondahookup.com</TD></TR></TABLE>
thanks got the online version but still wouldnt mind shortcuts or tricks etc.
Old Mar 8, 2007 | 06:20 AM
beanMosheen's Avatar
The Intake manifold support bolts are a bitch. You will need a couple of long extensions to get in there form under the car. Also make sure you're removing the two bolts you're supposed to. There are four. It won't hurt anything, but it will waste your time. Once you get the head out, you can cut that f$#@$#@$#@ support out, it's useless. If you decide to leave it, ignore the bolts if you find them to hard to put back in.
Old Mar 8, 2007 | 11:53 AM
shifts's Avatar
2.59pm.
Old Mar 9, 2007 | 02:40 PM
shifts's Avatar
5.43pm.
Old Mar 9, 2007 | 03:26 PM
EG6 ON STANDS!'s Avatar
bump this!!! i got the doch vtec del sol owners manual i plan on doing the same and removing the head and installing arp heads studs and cometic head gasket on my gsr block.
vectorsolid
86
Jul 14, 2008 09:49 AM
Franky61silv
Dec 18, 2007 09:31 AM
thunteg
Aug 16, 2004 10:04 AM
NyStreet's_4life
Apr 9, 2004 06:03 AM
chrisb
Jul 18, 2003 10:38 AM
