another no start
Old Mar 7, 2007 | 04:52 PM
berts95ej's Avatar
* B A N N E D *
Default another no start
its in a 89 crx si
-engine turns over
-no fuel pressure
-no voltage to the fuel pump
-main relay is new and passes main relay test
-check engine light comes on and stays on
-led light on ecu stays on (not sure what it means)
-fuses are all okay i do believe i forgot to check one, but it has something to do with the rear lights? honda book isnt in front of me and i dont remember
any thoughts would be pretty great. thanks ahead of time
Old Mar 7, 2007 | 10:24 PM
pegboy's Avatar
if relay is ok. ecu is a dud.
Old Mar 8, 2007 | 02:12 AM
berts95ej's Avatar
* B A N N E D *
okay ill get another one hopefully thats what it is, im sick of this thing sitting in my front yard doing nothing. thanks
Old Mar 8, 2007 | 09:19 AM
berts95ej's Avatar
* B A N N E D *
havnt checked the ecu yet im workin on getting a friend to let me put it on his car to see if it works. any other ideas till then?
Old Mar 8, 2007 | 09:25 AM
efking1985's Avatar
Default Re: (berts95ej)
run the pump to a switch thats what i did. i had thesame problem as u and just got sick and tired and ran the pump to a switch i have not had a problem.
Old Mar 8, 2007 | 10:52 AM
berts95ej's Avatar
* B A N N E D *
im selling it to my brother and i wanna fix it right before he gets it. im very suspicious of the ecu, it worked in the car it used to be in, then was taken out and sat for a while before i got my hands on it. so is there a way to sorta reset it so it works again, or what do i do?
Old Mar 8, 2007 | 04:58 PM
efking1985's Avatar
if ur getting a check engine light the ecu is working.
Old Mar 10, 2007 | 09:26 AM
berts95ej's Avatar
* B A N N E D *
alright ill try the switch install. what gauge wire are you using 16?18? and where are you pulling power from? thanks
Old Mar 10, 2007 | 09:42 AM
efking1985's Avatar
im pulling the power from my iginte switch so when i turn the key my pump turns on and im using 18 guage wire.
Old Mar 11, 2007 | 10:53 AM
berts95ej's Avatar
* B A N N E D *
okay so fuel pump is wired up through the radio power supply and works great. check engine light is flashing extremely fast and distributer makes clicking noise with checkengine light. anyone have anythoughts?
Old Mar 14, 2007 | 01:48 PM
berts95ej's Avatar
* B A N N E D *
okay so i have fuel pressure now and to the best of my knowledge the ecu is turning on. as soon as i can get some new injectors (turns out i have fuel leaks oops) im going to drain out all old gas, but new fresh gas in and new spark plugs and hopefully that does the trick.
Kenneth77488
Dec 23, 2013 02:17 PM
gtownjoe
Nov 28, 2011 08:52 PM
madmax94
Feb 28, 2011 02:03 AM
Red_Si
13
May 7, 2003 03:21 AM
wronghand
14
Aug 10, 2002 11:30 AM
