Trouble starting with low fuel
Old Mar 7, 2007 | 04:52 PM
Achenar's Avatar
Default Trouble starting with low fuel
I've noticed that in the past few months my car has trouble starting when I'm low on fuel. This happens when I have ~1 gallon or less left in the tank (low fuel light is not on).
Generally it will crank for 5-10 seconds (I can hear it struggling), and then finally it will turn over with RPM's very low ... then finally come up to speed.
Today I happened to get stranded, and could not start my car at all
I drove ~25 miles on the highway, reached my destination, killed the motor, came back 20 seconds later, and the car would not start! Fuel was low, but again, no fuel light. I tried cranking it for 10-15 seconds, and it actually turned over for a few seconds, but then died being fuel starved.
After waiting 30 minutes for AAA to come by with a gallon of gas, the car started up just fine.
The tank was still pressurized when I took off the gas cap.
Is it possible that there's a problem with my fuel sensor, and I actually have less fuel than I think?
-a
Old Mar 8, 2007 | 02:58 PM
Achenar's Avatar
Default Re: Trouble starting with low fuel (Achenar)
up
Old Mar 8, 2007 | 05:55 PM
VTiCSi's Avatar
how old is the car ?
did you check the fuse(s) and/or fuel light bulb?
if all of those are okay, it could be a stuck level inside the tank.
this happened me on Lancia Delta and I was stuck for-freakin'-ever thinking of what the problem was.
Old Mar 8, 2007 | 11:44 PM
Achenar's Avatar
Default Re: Trouble starting with low fuel (VTiCSi)
Car is a 2000. I know the light works (low-fuel light came on on my previous tank of gas on a road trip).
Someone suggested that my main relay might be bad, and to check for the sound of the fuel pump priming when I have low fuel.
Although to do that, means I have to conveniently be low fuel while I'm at a gas station, just in case. heh
-a
Old Mar 10, 2007 | 03:34 PM
B18cFreak's Avatar
maybe check the the fuel filter. chances are that when u run the gas down too low, all the crud from the bottom of the gas tank gets sucked through the system and could have clogged something. or u just keep on running it dry. jsut look at it this way, keep it full. even though the gas prices are terrible, ur gonna have to put gas in it n e was so... do urself a favor
Old Mar 10, 2007 | 05:14 PM
Achenar's Avatar
Default Re: Trouble starting with low fuel (B18cFreak)
Just replaced it 2k miles ago.
I generally keep it full, but on road trips, I tend to get my full tank's worth
-a
Old Mar 11, 2007 | 11:46 AM
B18cFreak's Avatar
i suppose its just the gas reader in the tank then. thats the only thing i can think of
GeoMetry
Mar 12, 2016 10:47 AM
Ajsbored
Jul 15, 2013 11:40 AM
Dan-Dillinger
Apr 21, 2006 11:26 AM
inane
10
Nov 2, 2004 11:15 PM
brockscivic
Jul 23, 2004 04:56 AM
