how to convert VSS cable to electronic
Old Mar 7, 2007 | 04:20 PM
F22B-EF's Avatar
Default how to convert VSS cable to electronic
got a 89 civic dx but with a obd1 motor and the car is converted to obd1 wondering how to convert it from cable vss to electronic cause its throwing a cel code
also i have a DC2 teg cluster so just wondering
Let me know thanks
a;so would i be able to swap back to my ef cluster and put a cable vss sencer in the tranny? motor is a f22b would a cable vss sencer out of a b18a work? or will i still have the check engine light??
Old Mar 8, 2007 | 08:11 AM
devnull's Avatar
If put the electronic VSS in and run a wire to the ECM and the cluster. The wire will be "Y"ed, to run to both.
Old Mar 8, 2007 | 09:11 AM
Darth_Accord90's Avatar
Default Re: how to convert VSS cable to electronic (F22B-EF)
You'll also need a speedo that uses the sensor instead of the cable. Any '90 and up should have what ur looking for.
GPC91
11
Sep 12, 2012 07:33 AM
dusterbd13
Oct 19, 2009 06:47 PM
JapJunkie
13
Feb 1, 2007 02:30 PM
toslowhatch
Nov 18, 2004 02:35 PM
PimpTightSi
Sep 18, 2002 06:52 PM
