yes.. another JDM SIR cluster question!!!
I got my cluster hooked up but i was wondering where i should hook up the power wire for the VSS? and if i need to run a fuse in the wire and what Fuse to use.???
yes dude..run the power to the switch power to cluster wire at the dash..if i remember right it's a yellow wire..just ground out the black wire, then patch the vss pulse into the vss at the speedo. on my speedo it was one of the yellow/red wires.
USDMSiR
15
Aug 31, 2006 02:07 PM
EF8IGHT
Feb 14, 2006 09:11 AM
