95 Honda Civic My Dash stays on I can turn the fan on and the air settings lights stay on
I have a 95 honda civic LX 4dr my dash stays on, I can turn the fan on even with the key out of the ignition in off position.
It keeps draining my battery because of a short or something is there a relay that can case this problem somewhere down by the ignition because it seems to be an ignition problem.
The air settings lights stay in (like the in side or out side air or if I want it to blow air on my face or my feet, those lights stay on and my battery is almost completely dead after 24 hrs,
and if I wait 48 hrs with out driving it I cant start the car
Yeah must be something like that i've been trying to check into it, I thought it might have been a switch or something but I don't even think there is an ignition switch for this car... any other ideas?, thanks
never did post the end results of what we found.... we found a couple wires had melted together around the fuse box under the hood, which then had to be wired from under the hood to the fuse box that is under the driver side dash/steering wheel... (we had to have someone good with electrical trace and wire and figure this out)
LOL 6 years later with the update! But I wish more people would post when a solution is found. kudos to you sir
choppyEG
Dec 14, 2021 05:15 PM
HONCORD
May 29, 2009 12:56 AM
