crx not turning on!!!!!!!!
Last night I parked my car. This morning i try to turn it on it wont start... My started will not crank (shoot out and spinn) and my i notice that my fuel pump is not clicking as well i cant here the fuel pump running... nothing is workin on my car exectp the radio and the headlight switch for headlights to turn on. Also my left and right turn signal switch.. and from my gauge cluster my light bulbs wont light up and.. and my check engine light and oil pressure light are very low as if my battery were to be dead....
So i got my bolt meter and checked. My main relay to make sure there was contiountly, and there is so its working
.. i check all my fuses none are burned.. even the once under the hood... i check how much volts my starter has and my alternator and they have 12.23 volts and also my front fuse boxs.
. WHat can be causing this problem.. there are some other big fuses under the steering wheel in my fuse box could they be burned? how can i check them?Man this is weired ****..
HOw can a car be working fine one day the next it wont even start or crack?
I would think the ignition switch would be semi intermittent, but i guess it could just go out, check it out, it does kinda sound like it could be.
Castanon
Oct 31, 2017 12:30 PM
vtec8200
Jul 16, 2012 03:16 PM
