obd1 tuning advice needed.
Old Mar 7, 2007 | 09:33 AM
Danno-7's Avatar
Default obd1 tuning advice needed.
Well, over the long cold winter I've scrambled together a bunch of parts for my car.
First and foremost, the car is a 91 DX hatch converted to mpfi and a d15b. Its currently running obd0 with a shitty tuned pr4 and a vafc. I hate it. With as much fuel trim pulled as possible with the bandaid fix vafc, its still pig rich. The car also blows a bunch of blue smoke above 5k. I don't think its rings as compression in good across the board wet and dry (Don't have the numbers handy, but I did check it out before the car went to the bodyshop for the winter). I was kind of leaning towards valve seals. This is my first Honda, and I'm admittadly inexperienced with them. Any input or ideas on the oil smoke above 5k?
Anyway, I have a fresh Z6 head, with a mild port and a crane 59100 cam, a skunk 2 cam gear and an STR intake maifold. I think I'll pop it on in the spring. I have gathered together everything for the obd1 conversion and need to decide on a tune, as the ecu will be chipped to my preference. The ecm is a p28 that will be chipped with crome. There is also a datalogging cable included for future use. Besides that, the car has a B&M fpr, an OBX header with a highflow cat/ Yonaka cat back exhaust, and an Si trans with an 8.5lb flywheel and a clutchmasters clutch & pressure plate.
As far as a tune goes, I was thinking about just a d15b map with an 8k redline, 4 wire o2 and no knock sensor. Other than that should I do anything else? I'm interested in the full throttle launch control but don't think I can use it without a VSS. I also have a NOS adjustable dry shot system that I was considering using with the 50hp jetting.
There are no local tuners or dynos, but I think that this would be a safe basic tune to get me up and running with the Obd1 conversion, and late spring or early summer I'll try and get some dyno time a few hours drive away.
Any input at all wold be appreciated.
Old Mar 8, 2007 | 10:12 AM
Danno-7's Avatar
Default Re: obd1 tuning advice needed. (Danno-7)
Wow.... no ideas guys?
epren
Jul 26, 2005 01:08 PM
I8ayellowcrayon
Jan 9, 2005 08:44 PM
50shotRex
Jan 8, 2003 09:50 PM
