More RPM
Old Mar 7, 2007 | 07:48 AM
Lindel's Avatar
Default More RPM
Need help on getting more rpm out of D series? any ideas?
Old Mar 7, 2007 | 07:51 AM
B18CivicEH2's Avatar
Default Re: More RPM (Lindel)
lmmfao...chipped ecu will take out rev limiter....
but why???are you even gonna be making power at high rpms?
Old Mar 7, 2007 | 07:54 AM
chris61988kb's Avatar
I take it your asking how to change ur redline point to a higher rpm, so u can pull up into higher rpms through each gear?
well the simple answer is to chip your ecu.
ofcourse your going to blow up your motor after a couple pulls.
what you need to do is beef up your motor and block. Id start with the motor first. You need to make the motor able to handle those higher rpm's then throw a chip in that changes ur redline to say 8000rpm or 9000rpm
ofcourse you need to beef up your block and motor or your just gunna mess stuff up BAD
this is something that is going to cost you ALOT OF MONEY
Old Mar 7, 2007 | 08:17 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: More RPM (chris61988kb)
Yeah, without serious modification you'll just be wasting time and engine health by reving past oem.
If it were that good of a mod to do to factory engines, we'd all be doing it.
steveharrmr23
33
Oct 3, 2009 01:56 PM
silly nanny24
66
Jun 4, 2009 05:30 PM
D17A2~VTEC
Jan 22, 2006 12:59 AM
allmotor235
Apr 23, 2005 09:09 PM
dominate9
Jun 17, 2003 03:14 PM
