88-91 cluster
Old Mar 7, 2007 | 05:36 AM
jbarker's Avatar
Default 88-91 cluster
ok if say u get a cluster guage off ebay and it has say 122,000 miles on the mileage can u turn those numbers back!
Old Mar 7, 2007 | 05:38 AM
p_diddy's Avatar
Default Re: 88-91 cluster (jbarker)
yes..
legal? no....
Old Mar 7, 2007 | 05:41 AM
jbarker's Avatar
Default Re: 88-91 cluster (p_diddy)
so how would u do it like with ?
Old Mar 7, 2007 | 05:45 AM
Creator's Avatar
Put a screw gun with a bit into where the speedo cable goes and turn it all the way past 99999999 and you've started back at zero....don't run it too fast or it will break it
I'm not sure what bit fits as a friend did it to an extra cluster I had just lyin around
Old Mar 7, 2007 | 03:13 PM
agbullit's Avatar
I have an extra cluster out of a 91 DX Hatch if interested. If you send me a pic of your current cluster, I can make the miles match for you. Let me know if interested.
Old Mar 7, 2007 | 03:17 PM
MagnaniEG6's Avatar
Default Re: 88-91 cluster (agbullit)
I used my finger to roll it back on eg cluster
Old Mar 7, 2007 | 03:42 PM
janz3n's Avatar
Default Re: 88-91 cluster (MagnaniEG6)
as long as your replacing the cluster say si with si you can swap over the odometer over.. rolling it back is illegal.
Old Mar 7, 2007 | 03:43 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: 88-91 cluster (Creator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creator &raquo;</TD></TR><TR><TD CLASS="quote">Put a screw gun with a bit into where the speedo cable goes and turn it all the way past 99999999 and you've started back at zero....don't run it too fast or it will break it
I'm not sure what bit fits as a friend did it to an extra cluster I had just lyin around</TD></TR></TABLE>
Worst advise ever! If changing mileage to match car, just remove the speedo from the cluster (4 screws), then 2 screws in the front, wrap a small wire around the base of the needle and pull up. Now you have the counter open, press firmly on what ever number you desire and turn forward, it takes like 10 seconds, literally. I can do the whole process in about 15 mins from start to finish.
Old Mar 8, 2007 | 08:34 AM
jbarker's Avatar
a whole other question but if i get a JDM 88-91 HONDA CRX/CIVIC EF8 EF9 VTEC CLUSTER B16A would i twork on a B18c GSR or not since it is V-TEC anyone no bout this by chance!
Old Mar 8, 2007 | 08:53 AM
JustAnotherRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbarker &raquo;</TD></TR><TR><TD CLASS="quote"> a whole other question but if i get a JDM 88-91 HONDA CRX/CIVIC EF8 EF9 VTEC CLUSTER B16A would i twork on a B18c GSR or not since it is V-TEC anyone no bout this by chance!</TD></TR></TABLE>
You sir, do not search much I take it.
You have to match the speedo- electronic or cable, to the cluster. JDM should be electric, so you'd need to change to an electronic VSS, whatever your tranny is match an electronic VSS to it.
eumoria
51
Nov 1, 2012 11:16 AM
xxwhixx
16
Apr 5, 2006 08:55 AM
BlueIntegraBoy
Jan 20, 2004 10:52 AM
B96v6
17
Aug 2, 2002 10:43 PM
