trans leaking from shift rod
Old Mar 7, 2007 | 12:13 AM
senoj's Avatar
Default trans leaking from shift rod
I just noticed that my trans is leaking from the shift rod. Should there be a external seal under the dust boot?
Transmission would be a lsd gsr
Old Mar 7, 2007 | 08:39 AM
ekb16's Avatar
ya there should be a seal that you can pop out to replace...if you move the dust boot u should be able to see it
Old Mar 7, 2007 | 12:40 PM
Bense's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">ya there should be a seal that you can pop out to replace...if you move the dust boot u should be able to see it</TD></TR></TABLE>
Old Mar 8, 2007 | 12:04 AM
senoj's Avatar
Default Re: (Bense)
ahh.. ok seal is missing then. i was thinking there would jus be an internal one. i looked at all my other D series tranys and there were no external seals.
mahalos.
civickid03
Mar 7, 2009 08:33 AM
six_speed
Jun 14, 2002 09:36 AM
