DOHC vtec del sol radiator
Old May 22, 2002 | 10:34 AM
B_CRUZ!'s Avatar
Default DOHC vtec del sol radiator
quick question... is the hose inlet and outlet the diameter of an integra or a civic?
Old May 22, 2002 | 10:41 AM
Kalokohan's Avatar
New User
Default Re: DOHC vtec del sol radiator (B_Cruz)
I have the same radiator in my car and i used my stock civic upper and lower hoses. This should be a direct bolt-on. Took me 15 mins. including draining the coolant. Got mine for $135 shipped from radiators.com
Old May 22, 2002 | 10:43 AM
B_CRUZ!'s Avatar
Default Re: DOHC vtec del sol radiator (Guardson3r3)
well i am using my stock cx radiator and i am using the stock B18C1 radiator hose and the integ hose is a lot bigger than the civic hose. i have no leaks though and i did buy the appropriate hose clamps.
Old May 22, 2002 | 11:13 AM
Jackson's Avatar
I believe they use the bigger integra clamps.
Old May 22, 2002 | 11:15 AM
BakedCookies's Avatar
same size as integra or 99-00 civic S!eye!
Old May 22, 2002 | 11:29 AM
The_Head's Avatar
yep, its plug in play. I also got mine from radiators.com You might want to think about replacing that CX radiator, since you have so much more power with the B18C5
my $.02
Old May 22, 2002 | 11:34 AM
Kalokohan's Avatar
New User
Default Re: DOHC vtec del sol radiator (xThexHeadx)
my $.02
Yup, my cx radiator lasted 3 months after my swap. I was at a light one day and noticed my temp needle on the red and coolant everywhere.
Old May 22, 2002 | 11:42 AM
jdmhatch's Avatar
So what parts other than the radiator itself would i need to install one in my 92 dx hatch with GSR swap? Thanx guys.
Old May 22, 2002 | 12:20 PM
B_CRUZ!'s Avatar
my $.02
i only have a weak b18c1 not a 5... lol
thanks for the input/help jackson, Guardson3r3, BakedCookies, xThexHeadx.
i'll order one soon for my "moneypit"... er i mean civic..
Old May 22, 2002 | 12:24 PM
Jonathan_ED3's Avatar
Default Re: DOHC vtec del sol radiator (jdmhatch)
i see everyone mentioning they got them from radiators.com..but i've been there and there is nothing specific about a 'DOHC' Del Sol..it just lists 'Del Sol 1.6l'. how do i know that i am ordering the DOHC radiator or not?
Old May 22, 2002 | 12:30 PM
The_Head's Avatar
Default Re: DOHC vtec del sol radiator (hot_EF)
I believe the DOHC VTEC Sols had the Dual Core radiator.
Old May 22, 2002 | 12:33 PM
yes...i know that. but i'm saying radiators.com doesn't have a 'DOHC VTEC' del sol listed....so how do you know you're getting the DOHC radiator?
Old May 22, 2002 | 12:37 PM
Kalokohan's Avatar
New User
I called and spoke to a rep. I told them I have a 96 Del Sol DOHC VTEC and they took care of me. The only thing you have to tell them is that if it's auto or manual. It's dual core and all metal.
B-Cruz, you just need the radiator. The radiator bracket you have now will work along with the cap and the hoses.
Old May 22, 2002 | 02:17 PM
The_Head's Avatar
I ordered mine almost a year ago, off the website and you had the option of three radiators for the 93-96(?) Del Sols, one of which was the DOHC VTEC Radiator. I guess its been changed.
gabebauman
Mar 4, 2011 07:46 AM
Mr. JDM-GSR
Feb 9, 2006 05:30 AM
som3on3_10
Nov 30, 2004 01:52 PM
delsolrob
10
Apr 27, 2004 08:57 PM
SpoonSportsJunkie
Sep 9, 2002 06:39 AM
