Can a timing belt be too tight?
Old Mar 6, 2007 | 09:38 PM
13g-crx's Avatar
Default Can a timing belt be too tight?
My timing belt on the b16 seems to be very tight. No play on either side at any point. Can it be too tight?
Old Mar 6, 2007 | 09:54 PM
.Manny.'s Avatar
Touching My Member
Default Re: Can a timing belt be too tight? (13g-crx)
yes it can be. im not sure how much play there should be, but there should be
Old Mar 6, 2007 | 09:58 PM
4DRmafia's Avatar
what could happen if the belt is too tight tho ? could it snap and screw up ur head, valve to piston kiss
Old Mar 6, 2007 | 10:02 PM
.Manny.'s Avatar
Touching My Member
Default Re: (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">what could happen if the belt is too tight tho ? could it snap and screw up ur head, valve to piston kiss</TD></TR></TABLE>
yes, all of those. just imagine all the stress at high RPM's
Old Mar 7, 2007 | 01:29 AM
HaRdCoRe-WeZ's Avatar
Indeed. Especially with the high revving B-series. Though i heard rumours that snapping the belt when you're not in VTEC won't ruin the engine...ow well, relatively.
In the Workshop Manual you can find how to adjust the timing belt the right way. I would check it ASAP if i were you...
Old Mar 7, 2007 | 07:59 PM
Hondasmo's Avatar
If the belt is too tight you will know it becuase the timing belt will be very loud under the timing cover
Old Mar 8, 2007 | 02:13 AM
BlueCrxNC's Avatar
I'm not sure on the DOHC motors but on SOHC you want just under 1" of deflection.
slide inside
Oct 22, 2009 09:25 AM
accordredliner
Jun 15, 2005 10:21 AM
OzWolfbane
Jan 7, 2005 05:14 PM
made in JAPAN
Feb 6, 2003 07:30 AM
TypeR1558
Nov 17, 2002 12:08 PM
